Go to Post I think CD is worth about 3 billion in Google stock. Talk about one hell of a fundraiser! - Joe Matt [more]
  #31   Spotlight this post!
Unread 09-02-2017, 10:22
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Re: H-Drive Strafing issues
Originally Posted by Peyton Yeung View Post
I had moderate success with a fixed mount h drive in the fall of 2014 albeit the entire chassis was made of folded 1/8" polycarbonate. The flex in the PC acted like a suspension for all the wheels.
All in all I would definitely take a look at 148's robots both their 2010 and 2014 strafe wheel assemblies.
So you didnt need to add suspension into the frame? We found ut if you drive forward slowly it strafes well.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
  #32   Spotlight this post!
Unread 09-02-2017, 11:53
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Originally Posted by cbale2000 View Post
I hate to go off topic, but in all seriousness how did this drive not self-destruct immediately? We've used solid 3/8" polycarbonate plates for our drive system for several years and it barely holds up (it tends to crack a lot). We keep using it because of the weight savings but we have to be very careful with it.
It never ran against other robots but it drove well. Each wheel was a single reduction off of a CIM which kept the gear meshes simple. It was incredibly flexible (both a blessing and a curse) which made for constant contact with the carpet. Never had cracking with the 1/8" PC even with the cold bending for the flanges.
461 Westside Boiler Invasion
45 Technokats
  #33   Spotlight this post!
Unread 09-02-2017, 11:55
45 Alumni
AKA: Peyton Yeung
No but the entire frame acted as a suspension since the polycarbonate is flexble. Probably not ideal for a full contact games such as Steamworks.
45 Technokats
  #34   Spotlight this post!
Unread 09-02-2017, 13:44
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
So think we will be good once we put it on the carpet?
  #35   Spotlight this post!
Unread 09-02-2017, 14:14
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Originally Posted by GeeTwo View Post
I suspect you were using acrylic (plexiglass), not polycarbonate (lexan). See my post in the Quotes thread yesterday for a description of the difference.
I don't think so, unless the supplier screwed up and gave us the wrong stuff. We did waterjet it if that makes any difference.
I'm a bit surprised you were able to keep the gears lined up with the amount of flex I would expect it to have plus the weight of the CIM motors hanging off. Makes sense that it didn't drive in a competition though, I'm not sure even bumpers would save that frame from a game like this year or last.
The carpet will definitely help but I STRONGLY recommend not waiting till you get to your first competition to find out. Try to find someone nearby with a practice field or pick up a small section of carpet comparable to what's used on the field from a local carpet store. There are few things worse then going to a competition and finding out your drive system doesn't run like you expect it to.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
  #36   Spotlight this post!
Unread 09-02-2017, 15:40
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
A picture of the robot in question would help us out a lot. I have built the exact same H-drive from the Vex Drive in a Day kit. It could barely even drive on linoleum or another hard surface. Driving on carpet was much more successful, but there's a large chance you'll still run into consistency issues. Now, you have a couple options open to you.
  1. Leave it as is. When you get to competition, you might be able to strafe; you might not.
  2. Take out the strafing module entirely. Then you'll just have a four wheel omni.
  3. Take out the strafing module and switch out your back two wheels for traction wheels.
  4. Lower the mounting point for the strafing module. You can do this in a variety of ways, from complex as welding the module to the current drive rails to as simple as getting clever with washer placement. This will mean there is more of the robot's weight on the strafing wheel, allowing you to actually strafe. However, this takes normal force off of your four main drive wheels. This means you'll have less traction when driving forwards, and your chassis may not sit flat on the ground.
  5. You can design and use some sort of actuating module like the VersaDrop or something completely custom to lower the strafing wheel when you need to strafe and raise it when you drive normally.
  6. You can design something like 148's actuating modules that use the the friction of the gearbox to provide downforce on the strafing wheel.
Those options are listed in rough order of difficulty. You and your team will have to decide which option is best for you.
  #37   Spotlight this post!
Unread 09-02-2017, 21:14
alephzer0's Avatar
alephzer0 alephzer0 is offline
Technical Generalist
AKA: Nathan Simon
FRC #1257 (Parallel Universe)
alephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud ofalephzer0 has much to be proud of
My team ran an H-drive in 2015, and had this issue for a while. Our solution was to use a spring to pull the module down while simultaneously acting as a suspension allowing for the robot to not get completely shaken off-balance upon hitting bumps.
I agree that a picture or model of the drivetrain would be extremely helpful for us to see where a solution could be implemented.
Simply put, if I can't see it, I can't solve it.
Nathan Simon
FRC Team 1257: Parallel Universe
2016: Mt. Olive district champs with 5624 and 1676, Bridgewater-Raritan finalists with 25, 3340, and 555, MAR DCMP winners with 225 and 341.
2015: North Brunswick District Finalists with 11 and 193.
2014: Clifton District Champs with 1626 and 869, 2nd seed alliance captain at MAR regional champs.
There are 10 types of people in the world: those who can read binary, and those who can't.
  #38   Spotlight this post!
Unread 10-02-2017, 00:29
Jono37's Avatar
Jono37 Jono37 is offline
AKA: Jonathan Yu
FRC #4739 (Thunderbolts Robotics)
Rookie Year: 2015
Jono37 is an unknown quantity at this point
Our team is also going with a H drive this year. We have found that it isn't difficult to put a sideways module on a pair of articulated arms. The plates we're using are cnc'd but you can cut them out of an old AM14U if you need to. They just have to have the Toughbox's hole pattern. Here's a picture: https://scontent-syd2-1.xx.fbcdn.net...f5&oe=589F53C9
Hope this helps.
