Go to Post Who says girls can't be cute, fun AND SMART?!? - Marisa Russo [more]
Unread 09-02-2017, 12:52
buddybu buddybu is offline
FRC #2903 (NeoBOTS)
buddybu is an unknown quantity at this point
Re: MindSensors SD540C Issues
Originally Posted by flemdogmillion View Post
What's so bad about wiring the Talons?
Thank you for your reply.
I didn't say the Talons were hard to wire, just that the SD540C controllers were more conducive to cleaner wire management. Since we are likely moving back to the Talons, the way we managed the wiring for the SD540C will also work quite well for the Talons.
Unread 09-02-2017, 13:57
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
What made them better for wire management? I'm thinking I might be more interested in CAN if wire management got even easier.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 09-02-2017, 14:40
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
I assume it's because nothing's permanently wired to the SD540 motor controllers. You can feel free to make CAN and power wires as short as you want without fear of having to blow $90 on a new motor controller.
Also, to answer OP's question, this may just be the reality of the motor controllers. SD540(B) controllers were found not to be very reliable, and were outclassed by the SPARK in every way. Based on other people's teardowns of the original SD540, I assume this motor controller is using very cheap construction methods and components, leading to these failures.
Unread 09-02-2017, 16:42
FRC #2903 (NeoBOTS)
Exactly.
[QUOTE-bobbysq;1642584]Also, to answer OP's question, this may just be the reality of the motor controllers. SD540(B) controllers were found not to be very reliable, and were outclassed by the SPARK in every way. Based on other people's teardowns of the original SD540, I assume this motor controller is using very cheap construction methods and components, leading to these failures.[/quote]
Thank you for this information, this is the first real information we've received. Do you have links to these teardowns that I can share with the electronics team? (I will also search, but if you have them at hand...)
Unread 09-02-2017, 20:26
Rookie Year: 2015
Here it is: https://www.amazon.com/review/R1JCF3...toys-and-games
These things could certainly have improved though.
Unread 09-02-2017, 22:13
FRC #2903 (NeoBOTS)
Based on our experience, I am not so sure about the improvement. These are brand new this year, so, the kinks may not have been fully worked out yet.
