Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 09-02-2017, 11:15
arushshah1 arushshah1 is offline
FRC #6203
arushshah1 is an unknown quantity at this point
Jetson GPU Usage
We've bought a Jetson TX1 board to do our vision work this year and I had a question on its benefits. We're not actually using the GPU module because we're not using any of the vision algorithms that it can accelerate. Given this, is there a benefit of doing vision on the Jetson over a cheaper board like the RPI3?
Unread 09-02-2017, 12:41
solomondg solomondg is offline
FRC #2898 (Flying Hedgehogs)
Rookie Year: 2016
solomondg is an unknown quantity at this point
Re: Jetson GPU Usage
Well the CPU is a bit more powerful than the rPi 3's, but that's about it. Comparing the jetson to an Odroid XU4 or C2 if you're not using GPU, the XU4 or C2 wins generally.
Unread 09-02-2017, 13:22
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
I highly doubt that. Thresholds, desaturates, and blurs are very common operations that can be GPU accelerated.
WPILib
GRIP, RobotBuilder
