Go to Post it's much easier to build safety in to a system than to add it on a Thursday at a regional. - dtengineering [more]
Unread 09-02-2017, 12:01
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: What wheel to use for the flywheel
Two banebots blue wheels, 3-7/8", seem to have good inertia. And they grip well. Only issue is the already talked about "film" build up on the wheels after shooting a lot of fuel.
Varying the compression even an eighth of an inch had a big impact, so make sure you're not using a narrow flywheel. The holes in the fuel will ruin all your planning.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 09-02-2017, 12:32
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
This is what we are using. https://www.mcmaster.com/#2497k16/=16a565k
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 09-02-2017, 12:44
ShIfTiNgBoT's Avatar
ShIfTiNgBoT ShIfTiNgBoT is offline
AKA: David
FRC #0649
ShIfTiNgBoT is on a distinguished road
Or conversely, not enough compression mixed with small wheels will be ruined by the holes.
Unread 09-02-2017, 15:12
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
Didn't realize there are two type of 4"wheel with 50a durometer
I order the stealth wheel and then see people talking about the compliant wheel.
Does anybody know how different they are
Should I buy the compliant wheel instead
Unread 09-02-2017, 15:21
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
There is a world of difference. The stealth wheels, while great for quick intakes and grippiness, have a lower moment of inertia and are not at all compliant. I would not suggest using stealth wheels as your shooter wheels.
Unread 09-02-2017, 15:24
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
My team actually have been using 4" x 2" Colsons, we filed the wheel down so that it wasn't crowned anymore and we have had amazing consistency so far.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 09-02-2017, 16:20
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Stealth wheels make great shooter wheels. Better than compliant wheels in our testing. We were easily able to shoot vertically upwards of 14ft vertically
Unread 09-02-2017, 16:34
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Our team has had a 90% built robot for the past 1 1/2 weeks.
We tried many things from weight of flywheel, adjustments to speed, varying the metering feeder wheels, indexing of balls, and shooter width.
We also incorporated the use of a PID using the VEXPro Versa gearbox with an integrated encoder using a 2-775 Pro setup.
The biggest factor we are finding are orientation of the balls as it enters our metering wheel and then shooter. Orient them all the same way and we will hit 29 of 30 shots. Orient them another way and we will miss practically all of them.
So how do we account for it?
Well, thats today and tomorrow's adjustment.
If that doesnt work, we will live with what we have.
If we slow things down a bit, we can achieve close to 80% accuracy.
If we shoot as fast as possible, we can shoot 30 to 35 balls in less than 5 seconds, making 50-60% of the shots.
Hopefully, with our adjustments today, we can shoot fast but achieve a much higher success rate.
If we can do that, we plan to share it with all of our Hawaiian friends here.
Unread 09-02-2017, 16:38
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We hit the 19ft ceiling in our shop shooting with the compliant wheels when we first ran them (CIM motor, 1:1 chain driven) at full power. We dialed it way back for further testing
2016: Lake Superior WFFA
Unread 09-02-2017, 17:14
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
It's almost like there might be more factors than wheel type when it comes to shooters.
Seriously though, I'm pretty confident we'll see effective shooters using a variety of wheel types. I am not confident that there is an "in general" superior shooter wheel when it comes to COTS parts. So many factors such as compression, feeding, and style of shooter will affect what characteristics you're looking for in your shooter wheel.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 09-02-2017, 17:31
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
I totally agree that you need to control how the ball enters the flywheel.
That said, I have a few specific questions:
1) what wheel are you using?
2) what compression are you targeting?
3) what exactly do you mean by a "metering" wheel? (I have a guess)
Unread 09-02-2017, 17:35
waialua359's Avatar
AKA: Glenn
1) what wheel are you using? Banebot Green wheels 2 7/8" diameter
2) what compression are you targeting? I failed to mention earlier that we have tried various compressions. We mounted our shooter wheel to the frame with aluminum blocks that allows us to easily swap out different widths adjusting the compression. We vary them by 1/8".
Similar to our flywheel that feeds balls into the shooter from the hopper.
Unread 09-02-2017, 17:54
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
What do you mean by the orientation of the balls? Aren't they pretty close to spherically symmetric?
Unread 09-02-2017, 17:58
Registered Muser
I agree. Just about any wheel can be used with success if the rest of the system is good. But if the OP is having issues with Colsons, I doubt stealth wheels will be better. Grnated, switching to compliant wheels probably won't make all their shooter problems go away either, but compliant wheels may be a better wheel for the rest of their setup than Colsons or stealth wheels.
Unread 09-02-2017, 18:21
waialua359's Avatar
AKA: Glenn
For a specific set of adjustments we tried to make to optimize success rate, we find that when the seams of the ball are perpendicular to the shooter wheel, it is much more consistent than lined up horizontally.
Our shot up close can change by as much as 2ft as well as varying velocity and arc path.
