Go to Post (Yes, I'm that much of a dork.) - Madison [more]
Unread 08-02-2017, 20:23
JohnGutowski JohnGutowski is offline
FRC #0280
JohnGutowski is an unknown quantity at this point
Entire Project Error
Our project is broken due to this wiring error, I can no longer connect any wires to our Begin.VI anyone know what this could be?
Screenshot: https://ibb.co/cDtVdv
Thank you
Unread 08-02-2017, 20:59
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: Entire Project Error
Go into your Begin file and create an Error Out box on the front panel.
In the top right of the Begin, there should be a hatched white box that allows you to wire front panel items as an input or output. Click the bottom right white box, then click the Error Out item.
Go back to Robot Main and relink that wire to the Error Out terminal on Begin.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 08-02-2017, 21:40
You deleted the error out from Begin (and you thought it wasn't doing anything...).
Unread 09-02-2017, 16:17
FRC #0280
https://ibb.co/eT5Pov
Error in and out were already there
Unread 09-02-2017, 16:25
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Delete the broken line. Rewire it to each VI, one by one. When it goes broken, you've found the problem. Someone deleted an Error In OR Error Out from one of those VI's.
To replace it, just copy it from any VI, and paste it. Right click on it and change it to a control or indicator (depending on whether it's in or out), then connect it via the connector pane. Save the VI.
Unread 09-02-2017, 16:31
FRC #0280
Thanks!
