Go to Post w0000000000000t! - Andy Baker [more]
Unread 09-02-2017, 16:43
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Re: Teleop Pausing Itself
Originally Posted by Hitchhiker 42 View Post
No. I did forget to mention that I had e-stopped the robot sometime around/before then. Could that have an effect?
I did cycle power and restart the code, driver station, etc. after that, though.
Estopping should be fine if you have rebooted everything. Are you getting any errors on the driver station?
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
Unread 09-02-2017, 17:05
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Yes - lots. However, all of the ones I'm getting are related to having things in code that don't physically exist yet, and are the same as before.
I do want to note that I pulled the same version from github and ran that and it worked fine.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 09-02-2017, 17:18
Open Robot Main and go to View->Breakpoint Manager and see what's listed there.
There might be two default breaks, but there shouldn't be any more.
Unread Yesterday, 14:21
Unexas Unexas is offline
Lead Programmer
AKA: Douglas Byrd
FRC #3753 (BulahBots)
Unexas is just really niceUnexas is just really niceUnexas is just really niceUnexas is just really niceUnexas is just really nice
You shouldn't be running the program by the arrow build it then deploy it and run it from the driver station.
Unread Yesterday, 14:24
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
He's probably just debugging the program, as an actual build/run as startup takes several minutes.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread Yesterday, 14:27
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
This is not true. LabVIEW is meant to be able to run without a full deploy. If you have a slow laptop or packet loss, that can cause the behavior you are seeing. In addition, any errors showing in the diagnostic window can potentially cause issues.
Unread Yesterday, 15:03
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
A slow wifi connection to the programming computer should not cause the robot to do anything out of the ordinary but it may cause indicators on the computer to be delayed. A slow wifi connection to the DS could cause some hiccups, however.
Are you seeing the pause button near the run arrow turn red? If so, what happens when you click the red pause button to un-pause?
Unread Yesterday, 15:50
Roboter
Rookie Year: 2015
Yes, the pause button turns red. When I un-pause it, it finishes that iteration of the teleop loop, and pauses on the next iteration.
Unread Yesterday, 17:13
Tom Line's Avatar
I was making the (perhaps incorrect) assumption that he was running the code on the driver station. Ever since we got rid of that hideously underpowered classmate 8 years ago, that's the way we've done it.
Unread Yesterday, 18:07
In the Teleop front panel or block diagram check under Operate on the top menu bar and see if Suspend When Called happens to be checked.
Unread Yesterday, 19:57
Roboter
Rookie Year: 2015
It is not checked. I do have a red border around the edges of the vi though.
Unread Yesterday, 20:29
A red border means you have a Breakpoint set somewhere.
http://digital.ni.com/public.nsf/all...25670D00547B7C
Unread Yesterday, 20:46
Roboter
Rookie Year: 2015
Thank you!
Unread Yesterday, 15:04
Just to pile on, ... err ... , I mean clarify, LabVIEW debugging involves running the VI interactively by pressing the run button
Each VI's compiled code is downloaded to memory, connections are established so that you can see panels, probe, breakpoint, change some values on panels, etc.
Once the code is working well, you build an exe and deploy it. There happens to be a way to compile debugging into an exe, but that is not used as often as the interactive case.
Greg McKaskle
Unread Yesterday, 15:07
Does deploying as startup produce the same pausing behavior?
