Go to Post FIRST is unlike every other organization or every other robot competition because it begs to you collaborate; it encourages you to be a better person through the help of others. - Amanda Morrison [more]
Unread 09-02-2017, 18:57
ColbySamuelson ColbySamuelson is offline
FRC #6320
ColbySamuelson is an unknown quantity at this point
How to program the movement
Yesterday the robot finally moved but no one was in control. I pressed enable on teleop mode but it just went. So how do I use labview to program it so I have to use the microsoft flight stick to guide the robot? Please help.
Unread 09-02-2017, 19:07
Re: How to program the movement
Did the robot move while it was Disabled, before you Enabled it, or only after it was Enabled?
For these tests put the robot up on blocks so moving just spins the elevated wheels.
1st test:
- Disconnect the joystick from the PC.
- Make sure no one is touching it while you do this-don't even hold it-just leave it sitting on table
- Reconnect the joystick
- Check on the Driver Station USB tab that the joystick appears and is in the correct USB position (you might need to click the Rescan button on that tab).
- Enable the robot and see if it still moves.
2nd Test (if Test 1 didn't work):
- Start by creating a new robot project.
- Don't change anything in the project-anything.
- Build it
- Run as startup
Tell us the results.
Unread 09-02-2017, 19:10
FRC #6320
It was after I clicked enable. No one was touching it.
Unread 09-02-2017, 19:52
I assumed no one was touching it when you Enabled from what you said. That's not what I was talking about.
Test 1 investigates the possibility that earlier someone was holding the joystick or the joystick was lying on it's side or upside down or on a table with a jumble of parts, when it was first plugged into the PC before the robot even entered the picture.
Neutral on the joystick is established when it is first plugged in and powered up. If it isn't neutrally centered when it is first plugged in, then neutral on the joystick will be ordering the robot to move even when no one is using it.
Test 2 eliminates the possibility that it's a user code error.
Think about approaching problems like this to eliminate possibilities and to simplify and isolate what conditions cause the problem.
