Go to Post TL;DR: The robot battery (and your car battery) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides. - Kevin Sevcik [more]
Unread Yesterday, 20:44
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Re: More Than Two USB Cameras??
Originally Posted by ajsmith View Post
I've seen this code in multiple threads here but I have never been able to get it to work. We always end up with the "too many simultaneous client streams" error whenever we try to switch to the second camera (setting allowcam1 to true). Any ideas on why this isn't working for us?
EDIT: We just tried a new robot program with just this code and got it to work. If anyone else has this error, we had to change the source in smartdashboard to "switcher," then RESTART the smartdashboard and the robot, and then it would work. I think the problem was that since the smartdashboard had started off streaming the usb cam 0, it never stopped streaming after switching sources.
What do you mean when you say you have to change the source to "switcher?"
