Go to Post Stratagy drives design, not features. - Wetzel [more]
Unread Yesterday, 02:50
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Climber help: thermal breakers.
Part of my teams strategy has been to have a fast climber. When I say fast I am talking sub 5 seconds. Our biggest factor on that is the thermal breakers.
We plan to use a two 775 pros, each with a 33.33:1 reduction. Using the tall robot size means that it would travel a little over 2ft to reach the top. On the 1.25in roller we are playing to use that ends up giving us a solid climb speed of about 7.5 seconds. CAD suggest that our worst case would be a 100lb robot. Across each breaker that would be 40.48amps assuming a gearbox efficiency of 90%.
I got 90% efficiency from some read I did on planetary gear systems and spur gears. I will admit that I choose that based on some hunch math. I was lead to understand that you would get roughly a 3% efficiency loss from every planetary stage. Using two per side that would equate to 94%. Then from there I plan to reduce using spur gears at a 2.1:1 ratio. It is my understanding standing from my reading that spur gears have a loss of 2-6% so I choose 4% loss for my happy medium. Putting that in to JVN got me my number of 40.48 amps.
Now I might be crazy but I would love a sub 5 seconds climb without adding motors. With a 20:1 gear ratio I would draw 67amps for for seconds, could the thermal breakers handel a spike of the current for that long. Also what would the main breaker risk be?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread Yesterday, 03:10
RoboChair's Avatar
AKA: Devin Castellucci
Re: Climber help: thermal breakers.
Risk of the 67 Amps through the snap action breakers, someone else will need to weigh in on that. Personal feeling is not of much concern because they reset.
Main breaker: 1% concern. You can dump 500 amps through it for over a second if I recall correctly. 140 amps can draw for well over a minute. Who has the chart?
12 Years and counting! Over a third of my life has been spent with FRC.
Unread Yesterday, 03:14
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
http://files.andymark.com/PDFs/am-0282_data_sheet.pdf
See the chart on the bottom right of the first page. You can go for ~5s at ~480 amps (120 * 400%).
Never worked with overloading snap actions before, but the chart on their data sheet shows that it should be ok to run 67 amps through one (167.5% of the rated current, which the data sheets say could be done for about .. 5s?
http://files.andymark.com/MX5SpecSheet.pdf
Unread Yesterday, 03:26
RoboChair's Avatar
Thanks for making up for my lack of immediate knowledge and vetting my ramblings! I really don't know where to find most things to link to these days. That's what crowd-sourcing is for right?
You must spread some Reputation around before giving it to ollien again.
Unread Yesterday, 07:37
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
I think you risk burning out the 775pros very quickly. Compare the stall conditions to a CIM.
Unread Yesterday, 08:02
Chris is me's Avatar
AKA: Pinecone
With two 775pros of power, you should be able to get a climb as fast as you describe without drawing anywhere near 60 amps per motor. [s]Is it possible you're on the "wrong" side of the motor power curve? You might be at the point where your under-load speed will actually go down if you increase your gear ratio.[/s]
Edit: Yes, your math is way off. Assuming you ONLY have the 33:1 ratio, and 80% efficiency, you should be drawing ~30 amps per motor and climbing in under 2 seconds with that setup, even with a 150 pound robot. Are you sure you selected the 775pro and listed 2 motors per gearbox in JVN's calculator?
Unread Yesterday, 08:05
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Theoretically, the OP shouldn't reach stall on a 775pro if he runs 60A, so stall conditions shouldn't matter. Still, the risk is there. Just always bring extra 775pros.
Unread Yesterday, 08:19
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Your ratios are what concern me. You should be able to make a sub-5s climb with a single 775Pro, a fully weighted robot, and more aggressive reduction. Have you used the JVN calculator to determine your speeds?
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Seed
Unread Yesterday, 08:39
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
What is the outside diameter of the spool you're using to climb. As others have pointed out, you should be able to climb comfortably in under 5s with just one 775pro, two should be more than enough.
We're looking at using a single CIM motor on a 9:1 ratio and the calculations are saying we should be able to climb in roughly 4 seconds and pull less than 30A (though obviously this will change somewhat as the strap winds up and makes the spool effectively wider). Given that a 775pro has about the same performance as a CIM when geared properly you should have no problem getting your climber to work.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread Yesterday, 10:46
Munchskull's Avatar
Team Role: CAD
I was using JVN calculator. This is all math right now, math that I realize my mistake with. I had used the intake math when I should have used the linear mechanism math.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread Yesterday, 12:31
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Disregard this post.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Last edited by flemdogmillion : Yesterday at 14:17. Reason: I was mistaken about the JVN calculator usage.
Unread Yesterday, 12:57
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
why would the math be different?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread Yesterday, 13:04
Munchskull's Avatar
Team Role: CAD
Originally Posted by flemdogmillion View Post
Note that when you are using a dual-motor setup like this, you are required to use 2 thermal breakers, one on each motor channel. I would not worry about 67A through two 40A breakers.
The calculations was 67amps PER motor.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread Yesterday, 14:03
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Check your math. I don't know what you've done wrong, but you've done something wrong with your math. If I punch in 2 775 pros, 30:1, 154lbs, 24 in, and 1.25 diameter pulley into JVN, I get 35A motor load, and a 0.82s lift. Which sounds much more like a 2 775pro lift.
Your numbers aren't even consistent assuming you got the motor load right. 40A = 30% FLA = 70% free speed = 12600RPM / 60 / 33 * 1.25 * pi = 25 in/s.
Unread Yesterday, 14:16
FRC #3007
Rookie Year: 2015
Oh. Well then. That'll be bad in a stall circumstance. Pardon me for my incorrectness.
Team 3007: 2017
