Go to Post In real life (IE when you go to apply your engineering skills to tasks in industry) there will be constraints on all sorts of things - many of which may or may not be "fair" or even "intelligent". You must learn to either work around them or use them to your advantage - preferably a bit of both. - OScubed [more]
Unread Yesterday, 09:31
fmercier fmercier is offline
FRC #3329
fmercier is an unknown quantity at this point
new 1.1 compressor blowing 20A fuses
I am a mentor with Team 3329. We had to replace our compressor this year and went with the new 1.1 from AndyMark. It is connected directly to the PCM, but it is blowing the small 20A fuses on the PDB. We've checked the wiring into the PCM, and have even replaced the pressure switch. Any suggestions?
Unread Yesterday, 09:36
Billfred's Avatar
Billfred Billfred is offline
Re: new 1.1 compressor blowing 20A fuses
Drop us a line at support@andymark.com. We'll take a look and get you running, whether by technical guidance or replacing it if it looks like a dud got through to you.
Sent from my desk at AndyMark
Unread Yesterday, 09:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Rule R56 allows the PCM to connected to a circuit breaker the PDB rather than the fused circuit. This will not fix a bad compressor but at least it will not blow the fuse that you VCM and robot radio is connected to.
Unread Yesterday, 10:05
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
How much current can the PCM handle in powering the compressor?
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread Yesterday, 10:15
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
The Weidmuller PCM/VRM Connectors are protected by a single 20 amp fuse (shared between the two). So, the combined current of the PCM/VRM cannot exceed 20 amps (I'm guessing that the peak current draw of the VRM is about 4 amps). If you want 20 amps for the PCM alone, then you need to use a WAGO connector with its own 20 amp breaker.
Unread Yesterday, 10:27
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
The PCM has current limiting built in. It is rated for 17 amps continuous. It will allow more for the start up inrush. A bit of history: The older FRC compressors were famous for blowing fuses on the spike relay on start up. FRC allowed replacing the fuse with an 20 amp circuit breaker for that reason. I suspect you have a similar problem.
PCM tech specs here
Unread Yesterday, 12:18
FRC #3329
Two questions:
If I go from compressor to a spike relay to PDB (20A fuse), would it work (no CAN connection)?
Would I damage the PCM if I try a 25 A mini fuse?
Unread Yesterday, 12:28
Zagar's Avatar
Zagar Zagar is offline
Electrical Mentor 1506 Metal Muscle
AKA: "Always waiting for Electrical..."
FRC #1506 (Metal Muscle)
Team Role: Electrical
Rookie Year: 2015
Zagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of lightZagar is a glorious beacon of light
Question for you: Did you install the replacement filter that Andymark sent out? The smaller diameter black one that is deeper?
If so, did you cut about 3 threads off of the part that screws into the compressor?
If not, the length of that threaded stem is so long that it will bind into the compressor crankshaft. This could be binding the motor so much that you're blowing fuses.
Thankfully I noticed this before installing the filter, and after some cutting and checking and cutting and checking, removing 3-4 threads safely clears the crankshaft, while still allowing a nice secure fit to the compressor.
Unread Yesterday, 12:33
FRC #3007
Rookie Year: 2015
Two questions:
Depends on what you use to control the relay.
Team 3007: 2017
Unread Yesterday, 13:58
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
This is a little troubling because that would be modifying a pneumatic component which isn't legal.
Unread Yesterday, 14:05
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Two questions:
By rule you can only connect the PCM to the 20 amp fuse connection (R52). I think it is a bad idea to power the PCM from there anyway since you allowed to power is from one of regular circuit breaker connections with a 20 amp circuit breaker (R56). Both cases specify 20 amp protection not 25. I don't like spike relays. The PCM is a way better solution.
Unread Yesterday, 14:10
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
You can use lots of Teflon tape on the threads to avoid modifying a COTs pneumatic component. It not like there any pressure on the connection.
Unread Yesterday, 14:29
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Zagar,
Thank you so much for pointing this out, we have been getting a few reports of blown fuses in 1.1 pumps and were not sure of the cause until now.
We will be sending an email to customers who received the replacement filters about this issue shortly recommending the use of a washer and/or PTFE tape to prevent the threads from interfering with the crank shaft without modification of the filter.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread Yesterday, 14:33
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Originally Posted by nathannfm View Post
Zagar,
We just ordered and received a 1.1 pump yesterday. How do we know if we have the new filter?
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
@OP:
1) Replace the wiring to the PCM, and PCM to PDB
2) Us a replacement fuse from a known good source, or at least a different one, and ensure that it is FULLY SEATED
3) Double check that you are not exceeding the duty cycle of the compressor
Per the 'modifying a pneumatic component' discussion. How is a venting filter, which retains/controls/stores no compressed air at all, a pneumatic component? I am confused, please enlighten me.
