Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
  #31   Spotlight this post!
Unread 10-02-2017, 01:38
lamk lamk is offline
Ken Lam
FRC #4719
lamk is just really nicelamk is just really nicelamk is just really nicelamk is just really nice
Re: What wheel to use for the flywheel
Originally Posted by Type View Post
My team actually have been using 4" x 2" Colsons, we filed the wheel down so that it wasn't crowned anymore and we have had amazing consistency so far.
We actually did that already and it didn't help. What is the compression your team use and how much of an arc that the ball contact the hood. Thanks.
  #32   Spotlight this post!
Unread 10-02-2017, 02:22
Valkonn's Avatar
Valkonn Valkonn is offline
AKA: Paulo Garcia
FRC #3495 (Mindcraft Robotics)
Valkonn is an unknown quantity at this point
Originally Posted by Cothron Theiss View Post
There is a world of difference. The stealth wheels, while great for quick intakes and grippiness, have a lower moment of inertia and are not at all compliant. I would not suggest using stealth wheels as your shooter wheels.
The inertia problem can be fixed with a flywheel. The design of a stealth wheel (partially hollow) also makes it easy to mount additional mass right into the shooter itself. And if your problem has anything to do with compliance, I'd say it's likely you have a problem with too much compression...
We were hitting the roof of our building quite easily at full power with blue 4 inch diameter stealth wheels. I don't know the exact number but its 25 to 30 feet of height. Couple that with extreme accuracy (hitting the center of a roof tile many times consecutively) and I'd say stealth wheels are a-ok for shooting.
Copy the best, screw up the rest.
  #33   Spotlight this post!
Unread 10-02-2017, 02:29
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Originally Posted by waialua359 View Post
For a specific set of adjustments we tried to make to optimize success rate, we find that when the seams of the ball are perpendicular to the shooter wheel, it is much more consistent than lined up horizontally.
Now I'm curious how you designed a hopper and indexer that could possibly line it up in a reasonable manner.
Academic Student (Forever)
  #34   Spotlight this post!
Unread 10-02-2017, 05:00
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
That's easy. By hand😃
  #35   Spotlight this post!
Unread 10-02-2017, 08:25
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
so what compression are you running?
  #36   Spotlight this post!
Unread 10-02-2017, 08:47
Chris is me's Avatar
AKA: Pinecone
I agree. Just about any wheel can be used with success if the rest of the system is good. But if the OP is having issues with Colsons, I doubt stealth wheels will be better. Grnated, switching to compliant wheels probably won't make all their shooter problems go away either, but compliant wheels may be a better wheel for the rest of their setup than Colsons or stealth wheels.
Stealth wheels perform dramatically differently than Colson wheels in terms of acting as a shooter. Please don't speak from experience if you don't have said experience - at least qualify your statements with "I think" and / or explaining why you're making the assumption that you are.
All that said, I've had great experiences shooting with compliant wheels, I think they're great for this game piece.
  #37   Spotlight this post!
Unread 10-02-2017, 09:12
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
Our compression we have been varying and due to welding right now, I've been separated from my team. I know that it is not a lot. The arc of the hood is very little.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
  #38   Spotlight this post!
Unread 10-02-2017, 13:23
Valkonn's Avatar
AKA: Paulo Garcia
About an eighth of an inch, maybe a few thousandths more.
  #39   Spotlight this post!
Unread 10-02-2017, 15:02
xjschwen xjschwen is offline
FRC #3668
xjschwen is an unknown quantity at this point
Our one wheel shooter prototype was an 8 inch wheel powered direct drive with a cim and we had plenty of distance and had some accuracy issues.
Our 4 wheel shooter prototype was 4 - 4 inch compliant wheels on 2 shafts powered by 2 mini cims. First prototype testing we hit the same 2" pipe along our ceiling for 10 shots in a row with plenty of power to spare. The pipe is about 12 feet straight up.
We did no further tests.
