Go to Post A good engineer will never stop learning. From his peers, technicians, and competitors. The field is just to vast for any one person to know it all. - Mr. Mike [more]
Unread Yesterday, 17:33
Espo Espo is offline
AKA: Ben
FRC #5113 (Combustible Lemons)
Rookie Year: 2016
Espo is an unknown quantity at this point
BUILD FAILED - Remote command failed with exit status 1
I have this error, which I can't figure out how to fix. I have the latest FRC Plugins and just imaged the Rio with 2017 v8. Here is the full output:
Buildfile: C:\Users\MHS\Documents\GitHub\FRC5113_2017\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\MHS\Documents\GitHub\FRC5113_2017\build
   [delete] Deleting directory C:\Users\MHS\Documents\GitHub\FRC5113_2017\dist
compile:
    [mkdir] Created dir: C:\Users\MHS\Documents\GitHub\FRC5113_2017\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\MHS\wpilib\java\current\lib\WPILib.jar;C:\Users\MHS\wpilib\java\current\lib\NetworkTables.jar;C:\Users\MHS\wpilib\java\current\lib\opencv.jar;C:\Users\MHS\wpilib\java\current\lib\cscore.jar to build
    [javac] Compiling 10 source files to C:\Users\MHS\Documents\GitHub\FRC5113_2017\build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: C:\Users\MHS\Documents\GitHub\FRC5113_2017\dist
    [mkdir] Created dir: C:\Users\MHS\Documents\GitHub\FRC5113_2017\build\jars
     [echo] [athena-jar] Copying jars to build/jars.
     [copy] Copying 4 files to C:\Users\MHS\Documents\GitHub\FRC5113_2017\build\jars
      [jar] Building jar: C:\Users\MHS\Documents\GitHub\FRC5113_2017\dist\FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-5113-FRC.local
     [echo] roboRIO found via mDNS
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
  [sshexec] Connecting to roboRIO-5113-FRC.local:22
  [sshexec] cmd : test -d /usr/local/frc/JRE
BUILD FAILED
C:\Users\MHS\wpilib\java\current\ant\build.xml:293: Remote command failed with exit status 1
Total time: 8 seconds
Here is our code - https://github.com/FRC5113/FRC2016_5...bce97d1b0d358d
I was not getting this error before I updated the plugins and reimaged the Rio. I have tried this on two different Rios, both on the same version - 2017 v8.
Unread Yesterday, 17:50
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Re: BUILD FAILED - Remote command failed with exit status 1
Install the JRE on the rio. There's a link to instructions in your error message.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread Yesterday, 18:09
AKA: Ben
Rookie Year: 2016
Sorry, that is the code from last year. You can go to the organization and click on this year's repository.
Unread Yesterday, 20:41
AKA: Nick Schatz
Answer remains the same. Your log output has this section here that tells you exactly what's going on:
On the linked page there's this little blurb:
Note: Whenever a new image is installed on the roboRIO (either when initially setting it up or later if the image is updated or reinstalled) the Java runtime must be replaced. This is an easy to overlook step so be sure to keep this in mind.
The process to install the JRE is super simple. The program does most of it for you.
