Go to Post "Nuclear" is pronounced "nu kli Er." It is NOT pronounced "nu kU ler." When you use this pronunciation, no matter how smart you may actually be, you sound like an illiterate dolt (are you listening, Mr. Bush?). - dlavery [more]
Unread 10-02-2017, 20:51
charlier999's Avatar
charlier999 charlier999 is offline
FRC #1662 (Raptor Force Engineering)
charlier999 is an unknown quantity at this point
Post Help! Timer Function in WPIlib.h
I found this inside of the WPI libary
PHP Code:
[url="http://first.wpi.edu/FRC/roborio/release/docs/cpp/classfrc_1_1Timer.html#a5f16e8da27d2a5a5242dead46de05d97"]http://first.wpi.edu/FRC/roborio/release/docs/cpp/classfrc_1_1Timer.html#a5f16e8da27d2a5a5242dead46de05d97[/url]
I put the line
Timer::Timer();
into the code.
Timer::Timer() means
PHP Code:
Create a new timer object.
Create a new timer object and reset the time to zeroThe timer is initially not running and must be started
When I built the code in eclipse, it came back with this error >
error: cannot declare member function 'frc::Timer::Timer' within 'Robot'
  Timer::Timer();
I don't know why its doing this. If you know please tell.
Thx.
