#16
Re: How do you program the navx mxp in labview?
The LabView installation link doesn't seem to work. I downloaded the library from GitHub, but where do I install it?
#17
http://www.pdocs.kauailabs.com/navx-mxp/software/ Download the zip, and run the setup.exe within it. It will install everything you need. There is a tutorial a couple of links under that page http://www.pdocs.kauailabs.com/navx-...aries/labview/ |
#18
I am able to download the .zip but when I try to extract it, it gives me an error.
#19
Which is why I said it doesn't work. Downloading the library directly from GitHub does work, but where do we install it?
#20
Just found out there was a temporary file that was corrupted on the download site, so please download it again and run the setup.exe which will install everything into the proper place.
#21
Do we need to set a device number on the navX Main in Robot Main?
#22
No, you do not need to wire anything to the Device Number or the Update inputs per the video tutorial linked to above.
