Go to Post Measure it with a micrometer, mark it with chalk, and cut it with an axe. This is not an exact science. - Jim Meyer [more]
Unread Yesterday, 21:45
orangeandblack5 orangeandblack5 is offline
Hates LabView - Uses It Anyway
AKA: Ian Stewart
FRC #5498 (Wired Devils)
Rookie Year: 2015
orangeandblack5 will become famous soon enough
Re: How do you program the navx mxp in labview?
The LabView installation link doesn't seem to work. I downloaded the library from GitHub, but where do I install it?
Unread Today, 01:47
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
You can get the navX Device Library from
http://www.pdocs.kauailabs.com/navx-mxp/software/
Download the zip, and run the setup.exe within it. It will install everything you need.
There is a tutorial a couple of links under that page
http://www.pdocs.kauailabs.com/navx-...aries/labview/
Unread Today, 07:56
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
I am able to download the .zip but when I try to extract it, it gives me an error.
Unread Today, 11:24
AKA: Ian Stewart
Rookie Year: 2015
Which is why I said it doesn't work. Downloading the library directly from GitHub does work, but where do we install it?
Unread Today, 12:18
Software Mentor
AKA: Scott Libert
Just found out there was a temporary file that was corrupted on the download site, so please download it again and run the setup.exe which will install everything into the proper place.
Unread Today, 14:29
AKA: Ian Stewart
Rookie Year: 2015
Do we need to set a device number on the navX Main in Robot Main?
Unread Today, 19:05
No, you do not need to wire anything to the Device Number or the Update inputs per the video tutorial linked to above.
