Go to Post The mission of FIRST is not just to promote science and technology, but to help every student involved to reach their full potential and achieve their dreams - Mike Ciance [more]
Unread 24-01-2017, 20:56
klink135's Avatar
klink135 klink135 is offline
The one dat pushes da buttons
AKA: Max Jorgensen
FRC #5050 (Cow Town Robotics)
Rookie Year: 2015
klink135 is an unknown quantity at this point
Labview Pwm/DIO ERROR -63195, need help
Labview is improperly/not writing pwm/DIO channels. I am currently unable to make any pwm work. It gives me ERROR -63195, and sometimes the driver station will say no robot code even when it is deployed. I have even made a brand new default robot project and it suffers from the error.
Unread 24-01-2017, 22:02
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Labview Pwm/DIO ERROR -63195, need help
This probably has nothing to do with it at all, but why does your PC CPU show pegged at 100%?
Unread 24-01-2017, 22:28
Have you formatted the roboRIO with the 2017-v8 image?
Unread 25-01-2017, 05:39
klink135's Avatar
AKA: Max Jorgensen
Rookie Year: 2015
Tom,
I don't really know, sometimes it just spikes and nothing was done to it.
Mark,
Yes, the Roborio and all following components are updated to the most recent firmwware.
Unread 25-01-2017, 07:17
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
Following...same exact error has happened to us on two different Rios. Spoke with NI and they sent us a config file, still same error. Will follow up with them again today.
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 25-01-2017, 16:32
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
With the default project, you'll create a connection to a pair of Talon SR motor controllers on PWM0 and PWM1. If you're using a different motor controller or different PWM ports, I wouldn't be surprised to see that error.
I'm making the assumption you don't change anything with the sample project. Is that a safe assumption? If so, what PWMs are you connected to and what types of controllers? I wouldn't be shocked to hear you checked that, but for completeness we'd want to see that.
If you get an error there, I'd want to see what happens if you replace the motor initialization code with just the Open Motor VI found in WPI Robotics Library->Actuators->Motor Controller
With that, you can open a single motor rather than two at once. If you open up the motor on PWM0, do you see the same error? If not, do you see it on PWM1? Once you find a single PWM port that's causing the problem, I'd try moving the PWM to PWM2. Does the error go away? If not, try changing out the cabling. Does the error go away now? If so, it could potentially be the port.
If not, try swapping the original cabling so the two PWM ports go to the opposite motor controllers. Does the error follow the port or the controller?
Unread 25-01-2017, 21:19
klink135's Avatar
AKA: Max Jorgensen
Rookie Year: 2015
The default project worked, and I tried rebuilding my code from scratch. This went fine until I put set outputs into teleop, that caused the first error. So logically I tried removing the motors in the program. It then said that encoders were the problem, so I removed the encoders. This process repeated until I had removed every input/output on the Rio, except for the can bus, which works fine. So I dug in and tried to find the source. The errors led me to the fpga open system.vi. In there it seemed the problem was the address of the Rio. I didn't take pictures. But I will try to post some soon.
Unread 26-01-2017, 09:18
The FPGA portion sounds a bit like a red herring.
Ultimately, all IO goes through the FPGA using a standard bitfile that you don't have to touch. If the bitfile itself was the problem, you'd have a problem right from the start. It's also a problem that every team would have because it's part of the imaging process.
You'll want to focus your attention on building out. If you start with the initial project, it includes a couple of PWM ports going to motors. If that doesn't error, you can try to add the next component on. If you're working with Command and Control, it's even easier to test in this modular mindset. Start with the drive subsystem and see if the error pops up. If it does, you know it's the most recent thing you added. Check the wiring. Check the hardware. Make sure it's responding. If it's not, you'd expect to see the error. Take a look at the lights on the motor controller when you enable. What do they tell you?
Unread 29-01-2017, 14:13
HSi HSi is offline
FRC #1712 (Dawgma)
HSi is an unknown quantity at this point
Our team has had the same FPGA and device handling error show up in our driver station and prevent our code from running when we enable. This has been happening on different robots and computers, and even with blank projects, all in the past week. As far as we know, none of the hardware on the robots has changed.
Interestingly, error -63195 is always preceded at the beginning of runtime by error -63192, which says that the RIO resource name is invalid. We checked it with NI MAX, however, and the resource name seems to be fine.
We suspect the problem is in the WPI libraries at the base of LabVIEW or on the robot and know that we didn't touch that code. Occasionally, rebooting the robot/roboRIO multiple times, clearing object cache, and removing code from the roboRIO has solved the problem, but none of these solution has been consistent--the problem still occurs intermittently.
The latest method we tried was shelling into the roboRIO and removing the "frc" folder, which appears to hold the LabVIEW libraries. So far it seems to work, but we're not sure yet whether it's a permanent fix.
Unread 29-01-2017, 20:38
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
We were having this error also, but we did a roborio complete format, and firmware load, and that seems to have fixed the issue.
The sooner we get behind schedule, the more time we have to catch up.
Unread Yesterday, 12:20
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
This error has now returned, we tried to diagnose, loading the default project with multiple laptops, and multiple roborio's. We have diagnosed that it is a single rio, (we have 4) that this error follows.
Any ideas?
Unread Yesterday, 14:44
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
So it seems to be an issue with the NAVX, we started rebuilding our project block by block, and everytime we add the NAVX communication loops this error is showing up.
Did the original poster have a navx too?
We were using SPI, and we have tried USB, and everytime we put in the code, the error shows up.
Unread Yesterday, 22:57
HSi HSi is offline
FRC #1712 (Dawgma)
Any ideas?
My team is using the NavX and we also had the problem. First, I suggest you make sure that your NavX libraries are located where the NavX software installer placed them. Regarding the problem as a whole, we believe we have found a way to evade the problem without removing the NavX from our code and robot. To summarize, our solution was to build a blank robot project down to the roboRIO (i.e. so the code runs at startup) and then build our actual robot project down. Here's some of the troubleshooting and reasoning behind it (though I admit this might not explain why only one roboRIO is having the errors):
We first noticed that the errors appear on the robot depending on what was deployed or built at startup. If a blank/standard project was the first project deployed after the robot was turned on or after the roboRIO was reset, every subsequent project deployed to the robot caused no errors. If the first deployment caused the -63192 and -63195 errors, then every project after also has the errors.
Hence, we built down a blank project onto the roboRIO, and every deployment was fine. We then built down our actual project just to see whether the act of building down could resolve the issue, and the errors stopped appearing as well. This seemed to solve the problem for both of our roboRIOs.
I'll put out a warning that the errors have occasionally appeared a few times during deployment of work-in-progress robot code, but they stop before the end of deployment and don't inhibit the functioning of the robot like before.
I would offer an explanation for this solution/"evasion technique", but unfortunately I don't completely understand it either, especially with the new information about the NavX communication loop causing the errors. Maybe our errors have two different sources. It would be great if someone could shed light on this.
