I found this inside of the WPI libary
PHP Code:
Timer::Timer(); Timer::Timer() means PHP Code:
error: cannot declare member function 'frc::Timer::Timer' within 'Robot'
Timer::Timer();
Thx. |
Re: Help! Timer Function in WPIlib.h
Try using this instead: frc::Timer()
Error
PHP Code:
Timer is not a function. It is an object. This should work:
#include <IterativeRobot.h>
#include <Timer.h>
class Robot: public frc::IterativeRobot {
public:
void RobotInit() {
timer = new frc::Timer();
private:
frc::Timer* timer;
START_ROBOT_CLASS(Robot)
https://github.com/wpilibsuite/Eclip.../src/Robot.cpp |
PHP Code:
Thx. |
If you have a timer defined, you can Get() what its time is. For example,
timer = new frc::Timer(); timer.Reset(); timer.Start(); double time = timer.Get(); |
