Go to Post The major items of FIRST are still what they always were.....understand the game, build a reliable quality machine to play it, train you drivers to use it to its full potential. If you do these things, you can win with or without any specific machine feature. - Jim Zondag [more]
Unread Yesterday, 18:40
Kyle Davis Kyle Davis is offline
FRC #5242
Kyle Davis is an unknown quantity at this point
SmartDashboard output help
Hi, I am having an error whenever I run certain code on the roborio.
When i commented out all of the code in method driveForward() except the variable declarations, the console doesn't output any errors, but when I uncomment and include leftEncoder.reset() and rightEncoder.reset(), I get an error that disables my robot. Any help is appreciated.
This is the code I am running:
package org.usfirst.frc.team5242.robot;
import edu.wpi.first.wpilibj.AnalogInput;
import edu.wpi.first.wpilibj.BuiltInAccelerometer;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.interfaces.Accelerometer;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboar d;
* This is a sample program to demonstrate the use of a soft potentiometer and
* proportional control to reach and maintain position setpoints on an elevator
* mechanism. A joystick button is used to switch elevator setpoints.
* WARNING: While it may look like a good choice to use for your code if you're
* inexperienced, don't. Unless you know what you are doing, complex code will
* be much more difficult under this system. Use IterativeRobot or Command-Based
* instead if you're new.
public class Robot extends SampleRobot {
//Drive Objects
BuiltInAccelerometer accel;
RobotDrive drive;
Joystick stick;
Encoder leftEncoder;
Encoder rightEncoder;
Accelerometer accelerometer;
final int kPotChannel = 1; // analog input pin
final int kMotorChannel = 7; // PWM channel
final int kJoystickChannel = 0; // usb number in DriverStation
final int kButtonNumber = 4; // joystick button
final double kSetPoints[] = { 1.0, 2.6, 4.3 }; // bottom, middle, and top
// elevator setpoints
final double kP = 1.0; // proportional speed constant
double motorSpeed;
double currentPosition; // sensor voltage reading corresponding to current
// elevator position
// make objects for the potentiometer, elevator motor controller, and
// joystick
AnalogInput potentiometer = new AnalogInput(kPotChannel);
Victor elevatorMotor = new Victor(kMotorChannel);
Joystick joystick = new Joystick(kJoystickChannel);
public Robot() {
public void driveForward2(float distance, float speed)
public void driveForward(float distance, float speed)
int pulsesPerRev = 1024;
double inchesPerRev = 6.0 * 3.141;
double currentSpeed;
double currentDistance;
double acceleration;
double deceleration;
double driveDelay;
currentSpeed = 0.0;
currentDistance = 0.0;
acceleration = 0.01;
deceleration = 0.02;
driveDelay = 0.01;
//rightEncoder.reset();
//leftEncoder.reset();
rightEncoder.setDistancePerPulse(inchesPerRev / pulsesPerRev);
/*while(currentDistance < distance)
SmartDashboard.putNumber("Distance", currentDistance);
if (currentSpeed < speed)
currentSpeed = currentSpeed + acceleration;
//drive.tankDrive(currentSpeed, currentSpeed);
drive.tankDrive(0, 0);
Timer.delay(driveDelay);
currentDistance = (rightEncoder.getDistance() + leftEncoder.getDistance()) / 2;
while (currentSpeed > 0)
currentSpeed = currentSpeed - deceleration;
if (currentSpeed < 0.0)
currentSpeed = 0.0;
* Runs during autonomous.
@Override
public void autonomous() {
//drive.setSafetyEnabled(false);
SmartDashboard.putNumber("start go", 1);
driveForward((float) 24.0,(float) 5.0);
SmartDashboard.putNumber("stop", 5);
//drive.setSafetyEnabled(true);
* Moves elevator to a selectable setpoint that can be changed by pressing a
* button on the joystick. Proportional control is used to reach and
* maintain the desired setpoint by obtaining values from the potentiometer
* and comparing them to the setpoint value.
@Override
public void operatorControl() {
boolean buttonState;
boolean prevButtonState = false;
int index = 0; // setpoint array index
double currentSetpoint; // holds desired setpoint
currentSetpoint = kSetPoints[0]; // set to first setpoint
while (isOperatorControl() && isEnabled()) {
buttonState = joystick.getRawButton(kButtonNumber); // check if
// button is
// pressed
// if button has been pressed and released once
if (buttonState && !prevButtonState) {
index = (index + 1) % kSetPoints.length; // increment set point,
// reset if at end
// of
// array
currentSetpoint = kSetPoints[index]; // set setpoint
prevButtonState = buttonState; // record previous button state
currentPosition = potentiometer.getAverageVoltage(); // get position
// value
motorSpeed = (currentPosition - currentSetpoint) * kP; // convert
// position
// error
// to
// speed
elevatorMotor.set(motorSpeed); // drive elevator motor
* Runs during test mode
@Override
public void test() {
