Code Won't Deploy
Hi, I am trying to deploy code to the robot and i build then deploy but, it still says i need to build it. Every Single Time. I have gotten it to deploy once but it said on the driver station that it had no code.
Is there a different firmware for the roborio if you run java instead of labview? We were going to use java but the guy who was doing it was put on academic probation. I only know labview. Any help would be great! |
Re: Code Won't Deploy
What you have to do is not build then deploy, but rather build then run as startup.
And to answer your other question, the same firmware supports LabVIEW, Java, and C++.
Also, does your code run correctly using the run button? Greg McKaskle |
I know the previous programmer installed the java runtime onto the roborio but i didn't know if i had to install a labview one for it to use labview again. |
