Go to Post If the refs are not calling something that you think should be called, you have to adjust your play style to deal with it. - Rob [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread Yesterday, 18:54
Jayd009's Avatar
Jayd009 Jayd009 is online now
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
Exclamation Raspberry Pi Stops PyNetworkTables
Hello everyone,
My team is attempting to create a vision processing system with a raspberry pi connected to the RIO through ethernet and with pynetworktables. Today, while we were testing, the pi just stopped sending networktables values. We couldn't change anything on the table. The server appears to be working fine on the RIO where we could change variables with the outline viewer from our computer, but nothing is working from the Pi. Everything is imaged, the pi is picking up a RIO on the network (verified with ping), we have the pi connected to the RIO by using the initialize command (with the mDNS name of the RIO), but nothing is working. When we ran the .isConnected() method on the pi, all it returned was false. We know we've set all the variables up correctly, but the pi just doesn't want to connect to the RIO. How do we fix this?
Code on Github: https://github.com/FernbankLINKSRobo...master/main.py
Thanks,
Jonathan Daniel
Head Programmer
Fernbank LINKS Robotics
2016: District Event Winner @ Columbus District Qualifier (PCH)
2016: Engineering Inspiration Award @ Peachtree District State Championship
2016: Tesla Subdivision Playoffs Appearance @ FIRST Championship
Unread Yesterday, 21:02
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Raspberry Pi Stops PyNetworkTables
I'm assuming that if you restarted the vision program then it would work again? Or did you try that and it didn't work?
Unread Yesterday, 21:05
virtuald's Avatar
RobotPy Guy
Also, was there any console output? And are you positive that your code loop was still executing (maybe inserting a periodic print statement?).
Unread Yesterday, 21:06
virtuald's Avatar
RobotPy Guy
Oh, also, you ignored the first rule when setting up pynetworktables -- NEVER use mDNS names, always use static IPs. Try changing that and see if it fixes your issue.
http://robotpy.readthedocs.io/en/sta...-configuration
Unread Yesterday, 21:48
Jayd009's Avatar
AKA: Jonathan
Rookie Year: 2016
We did attempt the static IP and it still wouldn't connect. It also wouldn't work after rebooting the Pi and the RIO.
Unread Yesterday, 21:49
Jayd009's Avatar
AKA: Jonathan
Rookie Year: 2016
The loop was executing, and it was running the lines responsible for inputting variables. We even tested it in the python shell cmd line and it still wouldn't input values.
Unread Yesterday, 23:13
virtuald's Avatar
RobotPy Guy
Did you change the code to reflect the static IP after switching (eg, NetworkTables.initialize(server='10.xx.xx.2') )
Unread Yesterday, 23:32
Jayd009's Avatar
AKA: Jonathan
Rookie Year: 2016
Yes. What's funny is that we were able to use the mDNS before this happened, and all of a sudden it just stopped. We didn't change any code, and it still won't pick up the tables. We're pretty sure it's in the right port on the radio.
Unread Yesterday, 23:35
virtuald's Avatar
RobotPy Guy
Yes, but mDNS has a tendency to not work correctly on the field, which is why I don't recommend using anything other than static IPs at this time.
Did you look at the console output of the RoboRIO via the driver station or netconsole? Maybe there were some errors there.
Unread Today, 08:45
Jayd009's Avatar
AKA: Jonathan
Rookie Year: 2016
We didn't look at the RIO output, we mainly looked at the outline viewer. I'll make sure to check that next time. Is there anything else you can think of that would cause the pi to stop?
