Go to Post “Chasing perfection is like trying to find a unicorn. If you go all around the world, you will not find a unicorn. However, you will find a whole freak load of stuff along the way.” - Karthik - Jacob Bendicksen [more]
Unread Yesterday, 23:14
microbuns's Avatar
microbuns microbuns is offline
AKA: Sam Maier
FRC #4917 (Sir Lancerbot)
microbuns is an unknown quantity at this point
View Non-Axis IP Camera in GRIP Desktop App
We have a working (non Axis) IP camera which is serving an HTTP MJPEG page which we can access in code via
cs::HttpCamera hikCamera("HikCam", "http://admin:<password>@10.49.17.11/Streaming/channels/2/httppreview" );
frc::CameraServer::GetInstance()->AddCamera(hikCamera);
frc::CameraServer::GetInstance()->StartAutomaticCapture(hikCamera);
This adds the camera to the CameraServer, and we can see the camera stream on the SmartDashboard. Additionally, we can also view this camera stream by adding the identical URL to VLC. Thus, we know this is the correct address, and both the robot and our computer can see it.
When we use a standard Axis IP cam, our GRIP desktop app works perfectly. However, when adding this camera as an IP cam in the GRIP desktop app, with the above address, it does not show up. It gives some kind of stack trace, but we can't highlight it because it spams the error box so fast, and the box is much too small to be able to see the important parts of the stacktrace (file names or lines), so we can't get that information as to why it is failing.
We are using the latest GRIP (1.5.2) and our camera is the DS-2CD2D14WD.
Has anyone got any other IP cameras than the Axis ones to work with the GRIP desktop app? Thanks.
Unread Yesterday, 23:33
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: View Non-Axis IP Camera in GRIP Desktop App
Please launch GRIP from the command line and share the error message.
WPILib
GRIP, RobotBuilder
