Lift Tracker - 1.0
LIFT TRACKER - SWAT 1806 S.W.A.T 1806 is proud to announce the first Lift Tracking software of the 2017 game FIRST Steamworks. No longer will mentors and coaches have to yell at the programmers to get vision tracking working, it's here. The software will recognize the distance from the target, and the angle to the target. This will also run on different processing computers like the PI and Kangaroo with relative ease. You can also easily edit this software by using the included GRIP file and generate the code that you like, no more messing with pesky HSV! How to install:
This is the GitHub link If you have any questions, feel free to post a comment or make an issue on the GitHub page and I'll be happy to look at it. Currently this is in beta, so please contact me for corrections. Thanks to:
FAQ: Q:What camera did you guys use A: Microsoft Lifecam HD3000 @ 640 x 480 Attempt #3 at trying to post my thread |
Re: Lift Tracker - 1.0
Looks awesome!
Any chance I could get a little more guidance/advice for a complete noob?
I'm a very good programmer but have not yet worked in the environments called for for robot programming. Just learning the LabView stuff for robot control. For instance... 1. The instructions say "install" opencv but when I go and download it from the site I just get a folder of libraries. There's nothing to install. So, are you really just saying "go download the libraries"? 2. Why do I have to download Network Tables 3.0 if it is already in the repo. I did a git clone of the repo so am I good with Network Tables? (Side note - I understand the concept of Network Tables but haven't used them yet - I'll be Googling that to try and figure it out.) It says make sure it is in the "build path". Build Path for what toolchain? 3. I download and installed GRIP for windows. I tried to open the .grip file and it crashed GRIP and wouldn't open. Is that because maybe I don't have the opencv files in the "correct" place or the Network Tables file in the right spot? 4. Export the project as a runnable JAR. Using what tool? I don't think if you respond it has to be in too much detail. Broad strokes are good. I can Google and follow-up with any unresolved issues after I work on it some more. |
Great job!
#7
1. Installing opencv is just the library, it should come with a file opencv_3.XX.jar or something like that. You put that file inside of your built path. 2. I included NetworkTables 3.0 in the repo so you can easily include it in the ECLIPSE built path. This allows you to use the different classes and methods from inside that jar in your project. You are good with the git clone once you get it inside the build path 3. I'm not really sure what is going on with that, I just installed GRIP on a fresh machine and opened up the GRIP file and it worked fine. Send me over a log file and I can check it out for you. 4. To export a jar, you go to File -> Export -> Runnable JAR from eclipse and it'll be good to run I hope this helps! PM me if you need any more help |
#9
Hello, we're new to vision this year, and we came across your github repository. We have used GRIP before to generate our code, and we have attempted to get the contours from the camera from the robot, but to no success.
We were wondering how we would incorporate your Process.java into our Robot.java class. How would we able to run it, without exporting it as a runnable jar file? Thanks ![]() |
#10
Awesome code. I looking to run this on a coprocessor (Jetson TX1). Would both liftTracker and processing.java run on the coprocessor or liftTracker on jetson and processing.java on robo rio. In processing.java you set the IP for networktables. Is this where your getting the network tables from and would that IP need to change for the jetson. Also your pulling a table called LiftTracker but in GRIP the network table published is still called myContours. Also setting up the camera steam ( I am using USB camera) I am assuming I would have to change IP to jetson as well (probably would have to create a mjpeg server?) and then also try to send it to the Driver Station.
Sorry for so many questions Thanks! |
#12
tracker.process(Mat) Quote:
NetworkTable.setIPAddress("roborio-1806-frc.local");
videoCapture.open(0); |
#13
And so the GP train continues. Awesome that you guys did this!
Have you benchmarked it to see resource usage on the roborio? I know that running two JVMs can eat up most, if not all, of the resources. |
#14
Nah we haven't tested it on the rio, we have only tested it on our drivers station computer and soon the pi / jetson
