Glad I have more than six weeks with you.
Unread Today, 16:37
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: How to use FRC Events data to determine gear ability
Originally Posted by ngreen View Post
Someone just needs to write a program to do vision processing on the scoreboard (streaming graphics) to get the times when the rotors are scored. And use that as a rate (gears/sec) for the alliance. If they score 4 rotors, then you'd have 4 rates (0->1 (1 gear),1->2 (2 gears),2->3 (4 gears), 3->4 (6 gears), so you'd have to consider which one best represents abilities. I'd probably eliminate Rate 1 and then use either the longest period or maximum rate as the rate for comparison. I lean toward the maximum teleop rate, but am not sure which would be better (I'd also consider combining any teleop rotor scores and calculate the rate from that). Without further data I'd put this all into a component OPR to break it out for each team.
This is just an idea between solely using API data and counting gears with scouts. I wonder a little if the FMS system could provide timestamps with rotors scored to facilitate a gear rate calculation.
I like this idea because it is possible to go back and score matches where no good scouting data exists as long as the matches are posted online.
I think it might be possible to get a fuel rating system working as well. I suppose that you'll be able to tease out when high and low boilers get loaded with balls.
I remember seeing a "how to make a poker playing bot" tutorial that makes me think that this falls into the "just work" category (a lot of work but manageable sub problems).
Down the road, perhaps FIRST would be willing to share more FMS data (e.g. real-time scores with a reason for every change)?
Think of the OPR refinements folks could make...
Dr. Joe J.
Team #88, TJ2
Unread Today, 19:45
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
I had this same idea a few weeks back, and sent a request to FIRST HQ. I was told the request was forwarded to the Engineering department, but haven't heard anything else.
First Name: Caleb
Last Name: Sykes
Email Address: calebsyk@gmail.com
Area of Interest: FIRST Robotics Competition Questions / Comments:
To whom it may concern,
My name is Caleb Sykes, I am a mentor for FRC team 4536. I am planning to use data provided by the FRC Events API (http://docs.frcevents2.apiary.io/#) to create team performance statistics and match predictions this year. This API is an excellent resource, and I really appreciate having it available.
One of the issues I expect to run into this year is accurately determining how many gears are scored in each match. I anticipate that the number of placed gears will not be recorded each match, and hence will not be available from the API, although I would love it if I were wrong. I expect the API to record the number of rotors which are spinning at the end of each match, and this will indirectly provide me some information on the number of gears that were placed. I was wondering if it would be possible for the API to, in addition to providing the number of scored rotors, provide timestamps of when each rotor begins spinning. I think it is possible the FMS already records this information, in which case exposing it to the API would be very plausible. These timestamps could be used in many different interesting ways to determine how good teams are at scoring gears, and would hopefully not require much effort on your part to implement.
I would really appreciate it if the API exposed this information, or something like it, in order that better statistics could be generated.
Thank you for your time,
Caleb
