Our software is compatible, baby.
Unread Yesterday, 17:04
Chieftainator1's Avatar
Chieftainator1 Chieftainator1 is online now
AKA: Carson Ausra
FRC #5182 (The Chieftainators)
Rookie Year: 2016
Chieftainator1 is an unknown quantity at this point
Tachometer and Custom Dashboard Help?
Hello There! My Team and I are attempting to use an tachometer connected via DIO, to get the speed of our shooter's wheel, we've got a program we think will work, but we don't know how to display the counter number onto a dashboard i'm fairly certain that we need a custom dashboard but I've got no clue on how to set one up or use it with the driver station... Any help is appreciated!!
Unread Yesterday, 19:02
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Driver
whitetail is an unknown quantity at this point
Re: Tachometer and Custom Dashboard Help?
What language are you programming in?
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590 and 2607)
2016 MAR Hatboro-Horsham District event Winner(Thanks 2607 and 1218)
Unread Yesterday, 19:16
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Judging by the fact that this is in the LabVIEW subforum, I'd venture to guess they use LabVIEW.
Sending values to the dashboard in LabVIEW is very easy. If you are using the default dashboard, use the Smart Dashboard Write vi to send the value to the name "DB/Slider 0". Then when the robot is running, open up the default dashboard and switch to the Basic tab and your number should be in the top number output. It gets a bit more complicated if you want to use a custom dashboard, but if all you need is that one number then that's not really necessary.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread Yesterday, 20:11
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Are those values still connected in the default dashboard? Or am I just thinking of the default custom dash template?
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread Yesterday, 21:04
Ari423's Avatar
FRC #5987 (Galaxia)
IIRC the default dashboard has all the values on the Basic tab bound to their names (in one of the loops below the "don't touch this" line). I would check that, but my LabVIEW expired last year and since I'm not programming the robot anymore I've been too lazy to put in the new activation code. Someone can check my memory if you want to be sure.
2013: Programmer
Unread Today, 09:50
FRC #3007
Rookie Year: 2015
The default custom dashboard template no longer has them bound. They added a "dashboard simple" template, I'm not sure about that one, I've only ever used it once and I deleted the whole Basic tab.
Off topic: Have you ever used the VIremote app for iOS?
Team 3007: 2017
Unread Today, 10:48
Ari423's Avatar
FRC #5987 (Galaxia)
That's a shame! I liked being able to make simple dashboard displays using the default dashboard without having to change any code. I guess I should actually download the new LabVIEW and play around with it if I get some free time.
I have not used the VIremote app yet. Might be an interesting tool for debugging if setup and integration isn't too much of a hassle.
2013: Programmer
Unread Today, 10:55
FRC #3007
Rookie Year: 2015
It's not a debugging tool, it just lets you control a front panel from an iOS device, as well as get various data from the device. It works great with Google Cardboard.
Team 3007: 2017
Unread Today, 11:01
Ari423's Avatar
FRC #5987 (Galaxia)
If I understand correctly, the app connects over wifi so it can't be used in competition. It could be used, however, to get data from the robot at home while debugging.
2013: Programmer
Unread Today, 14:00
FRC #3007
Rookie Year: 2015
You are correct in assuming that it's not legal for competition, but nothing is better than an offseason VR driver station.
I'm pretty sure and Oculus VR has enough resolution to do a full VR dash rather than a simple dual camera display. But the Oculus takes away all the programming fun, since you (IIRC) can set it up as two displays and just run two separate default dashboards set to their respective cameras. Not only that, but you could set up the Oculus hand controllers as joysticks for driving.
Although Oculus is so much nicer, I still prefer VIRemote. It's so much more fun.
Team 3007: 2017
Unread Today, 14:35
The easiest way to present a numeric number is to write to DB/String 0 through DB/String 9. Format the number, any way you, like to a string and write to the variables listed above.
If the range works, you can also write to DB/Slider 0 through 3. There are LEDs and buttons too.
Beyond that, you can make a custom DB. Controls placed in the Custom tab are still bound by name.
The difference between simple and default DB are ...
Default
2nd camera - simple supports just one on the left pane
Test - allows you to view sensor and motor configuration, values, and experimentally modify many values.
Commands - Interactively fire a command for testing
Checklist - Display a text file and support checking them off as part of drive team procedure
Simple
Missing the above features, but the diagram is considerably simpler, therefore a much better template for many to start with.
If you identify that binding or other features don't work, please bring it up.
Greg McKaskle
Unread Today, 15:28
AKA: Carson Ausra
Rookie Year: 2016
We can't seem to find the "Smart Dashboard Write vi." Where would it be located?
