We go together like a Drill motor, reduced by 3.6:1, and a CIM motor.
Unread Yesterday, 19:16
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Tachometer and Custom Dashboard Help?
Originally Posted by whitetail View Post
What language are you programming in?
Judging by the fact that this is in the LabVIEW subforum, I'd venture to guess they use LabVIEW.
Sending values to the dashboard in LabVIEW is very easy. If you are using the default dashboard, use the Smart Dashboard Write vi to send the value to the name "DB/Slider 0". Then when the robot is running, open up the default dashboard and switch to the Basic tab and your number should be in the top number output. It gets a bit more complicated if you want to use a custom dashboard, but if all you need is that one number then that's not really necessary.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
