For Valentine's Day, I will spoiler with a spring bouquet.
Unread Today, 14:07
shadow.tar.gz's Avatar
shadow.tar.gz shadow.tar.gz is offline
AKA: Manpreet Singh
FRC #3786 (Chargers)
shadow.tar.gz is an unknown quantity at this point
Gyroscope -> Arduino -> RoboRIO
We're trying to use a Gyroscope on our robot this year. The gyroscope we're trying to use is the Adafruit BNO055. So far, the way we're found to get information from it is with an Arduino Driver that adafruit provides. So naturally we are trying to get the data from the gyroscope with an arduino, and then trying to pipe it to the RoboRIO.
We got the arduino to read the Gyroscope no problem. But now we're trying to get the arduino to pipe the data to the RoboRIO via the I2C bus. We threw some code together, for both the RoboRIO side of things, and the Arduino side of things.
So the trouble is, we don't know how to use the Wire library on the Arduino to send the gyroscope values back to the RoboRIO when it asks for them. We got the RoboRIO to send over data to the Arduino, telling it what to send, but we can't get the arduino to send anything back.
When sending data back to the RoboRIO(the master) device, do we need to specify the address of the device? Asking since the Arduino acts as the master device to the Gyroscope, but a Slave device to the RoboRIO.
We've tried the I2C address scanner code to try and find the address for the roborRIO that way. But then we found that there was a board from Rev robotics called the RIODuino, which has example code using the I2C bus. So we found that the examples used the address of 84. We tried telling the Wire library to begin a Transmission with device 84, but that made the Arduino sketch crash.
Is it worth it to try and write our own Driver for the Gyroscope and remove the Arduino middle man altogether?
Unread Today, 14:10
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Gyroscope -> Arduino -> RoboRIO
Buy a NavX, avoid the headache altogether. One of the best controls investments your team can make.
"The breakfast of champions!"
Unread Today, 14:15
Brian Michell's Avatar
Brian Michell Brian Michell is offline
Timelord and programmer
FRC #6488 (RoboRams)
Rookie Year: 2015
Brian Michell is an unknown quantity at this point
This year we tried to use an Arduino to send gyroscope and acrostic pinger values to the roboRIO. Using a formatted serial.out() we could pull the separate values out using a VISA read. If you're using LabVIEW, I can post some sample code we are using for autonomous when I get home.
2015-Programming, Drive Coach (Worlds)
2016-Programming, Drive Coach
6488
2017-Programming
Unread Today, 15:05
Andrew Lobos Andrew Lobos is online now
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
I've used the BNO055 on some personal projects involving a cRIO - here's the "driver" I wrote for talking to it (mostly based on Adafruit's python library): https://github.com/4ndr3w/BallBot/bl...ter/BNO055.cpp
Some notes if you move forward with something based on this:
  • Since this wasn't a competition robot and just a fun project, I just used while loops to structure the init process. You DO NOT want to copy-paste this as-is in your code - it will lock up if the gyro doesn't finish initializing
  • getYaw() assumes big endian
  • If I remember correctly shift-left by one is an artifact of the cRIO addressing and not required on the roboRIO
EDIT:
Just wanted to tack on that there are a ton of COTS gyro solutions that let you avoid headache, like Oblarg said:
- WCP's Spartan board with the ADXRS450 gyro (we use)
- CTRE's Pigeon IMU
- NavX
- If you're just looking to do some simple gyro turns/drive straight in auto, you could use an analog gyro and be pretty safe
2012-2014: 225 Driver, Programmer & Co-Captain
2012-2014: FTC 4977 Driver, Programmer, & Team Captain
2011: 225 Operator & Programmer
2013: FRC: Springside-Chestnut Hill Winner (w/341 & 1495), Midknight Mayhem Winner (w/316, 369, & 869), Battle O' Baltimore Winner (w/1640, 2914 & 339), Duel on the Delaware Finalist (w/816 & 369), Ramp Riot Winner (w/341, 304, & 4637) FTC: PA State Finalist
2014: FRC: Springside-Chestnut Hill Winner (w/316 & 1495), Greater DC Winner (w/1731 & 4464), Midknight Mayhem Winner (w/25, 1626 & 329) FTC: PA State Champion
Unread Today, 15:16
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
I'm curious, if you are already using i2c, why not interface to the sensor directly?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
