Go to Post Ideally, you'll make sure your drive system can handle some Irritating Failures without them becoming Paralyzing Failures. - Billfred [more]
Unread 22-01-2002, 20:35
Tom Fennell Tom Fennell is offline
#0112 (Gear Grinders)
Tom Fennell is an unknown quantity at this point
Send a message via AIM to Tom Fennell
Question Wiring of Torque Motor
Does anyone have any idea how to wire the Belimo Torque motor? Can we just use the 1st 3 pins? Sorry we're clueless, we're just looking for somewhere to start....
Tom
Unread 23-01-2002, 00:01
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
The Torque Motor should have a diagram on it. If I rember correctly, it is the first two pins. We hooked one up to see just how slow it goes. Let Me Tell You: That thing is SLOW! Good Luck! 8)
Unread 24-01-2002, 23:44
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Cut a PWM cable in two pieces, then use the female end to plug to the torque motor. I believe you plug it into pins 1, 2 and 3, using two of them as positive and negative. There is a drawing of the polarity right above those pins, follow it.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 25-01-2002, 20:26
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
This link may just confuse you more but here it is!
HOOKUP: http://www.belimo.com/mft/Specificat...SpecControlVDC
SPECS:
http://www.belimo.com/mft/ActuatorDe...roduct_ID=4764
http://www.belimo.com/mft/ActuatorSe...es=LM&Spring=0
A pic and the 250 price now dats outragous!!!!!!!!!!!!!!\
Here is there homepage: http://www.belimo.com/
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
speeding up the torque motor archiver 2001 2 24-06-2002 00:13
How fast is the torque motor? archiver 2001 3 23-06-2002 22:55
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
