Thread Tools |
Rating:
Display Modes |
If you are going to make a CUSTOM gear from legal kit material, then you are often limited to 1/4 inch face widths because 1/4 inch plate is unlimited on the Additional Hardware List.
If you are buying off-the-shelf gears, then you can buy whatever facewidth you can find off-the-shelf. If you need to make a custom gear AND you want a facewidth greater than 1/4, you can perhaps buy thicker plate stock or even bar stock from Small Parts and use that to have your gears cut. Joe J. |
| Thunder Chicken CCT | Simon G | Motors | 4 | 03-01-2003 13:18 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drivetrain help | thedillybar | Technical Discussion | 9 | 08-01-2002 21:54 |
| Drivetrain Help | Jordan | Technical Discussion | 16 | 02-12-2001 12:14 |
| Drill motor gearBox question | Dennis Hughes | Motors | 4 | 11-10-2001 07:11 |
