Go to Post Enjoy doing what you do. If you enjoy your life, what you're doing in it, and how you're living it, then what other people say or think doesn't matter. - Beth Sweet [more]
Unread 25-04-2003, 00:11
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
Linux
OK, its 12:09am and my PC is giving me grief so I decide to wipe it and install Mandrake 9.1 on it.
I am in the middle of installing it now and its already given me some errors about my Hard Drive.... is there any major thing I should look out for?
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 25-04-2003, 00:21
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
If you post the error message you're getting, it'd be a lot easier to help you...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 25-04-2003, 00:27
MattK's Avatar
Tap it.
Well, It was a issue with my partitions... but beleave it or not I had to use my windows 2k installer CD to make the partition. It seems to be working now
my myspace!
Unread 25-04-2003, 21:52
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
I would have suggested RedHat 9. Brand new, awesome. Free. And the install is like magic. If you have a free partition, you can set up a dual boot with a few clicks. Like I said, its magic.
Unread 25-04-2003, 21:54
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
I got a cd copy of Yellowdog Linux from a friend on the robotics team. I tried installing it on one of my computers. It is a Sony Vaio currently with Windows95, a 3 gig hard drive and a slow processor. It has one cd rom but does not auto-play a cd, which I will mention in a minute. The txt readme file says to insert the cd, reboot, and hold the "c" key while the computer boots. I did that and a screen said, "Error: a key on the keyboard is stuck in the down position. Please fix this problem and press Esc to continue." It said that I could press F1 for the setup screen so I did. I set the cd-rom as the primary drive and the hard drive as the secondary. It still booted Windows. I can't find any possible way to install Linux on that computer.
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 26-04-2003, 10:39
fred's Avatar
fred fred is offline
More Grizzle
None #0341 (Daisy)
fred is on a distinguished road
Last time I got mad at my computer I intalled an ice-pick into its monitor.
"The distance between genius and insanity is measured only by success."
-Anonymous
Unread 26-04-2003, 12:24
#1067 (SLUH)
robot180: What the readme probably means is that it wants you to boot from the CD. The press the 'c' key down probably will accomplish that on *some* motherboards, but not all.
What you need to do is this: get into the BIOS. once you here your mobo beep after pressing the button (the mobo beep, not your speakers) hit the delete key (you only need to do it once, but I usually mash it untill I see the BIOS come up) and then you will get into the BIOS. it looks like a really old school computer display. search through the options untill you find the boot order, usually its defaulted to floppy, then Hard drive. What you need to do is set it so that it boots from your CD drive first. Then, save and exit, put in your CD, turn it on, and it will boot to your CD.
Unread 28-04-2003, 21:40
robot180's Avatar
AKA: Jon
I tried that already and it skipped the cd rom and looked for the floppy and then the hard drive. It just skips the cd rom.
-Jon
Georgia Tech
Former Team Leader
FRC Team 180
Unread 28-04-2003, 21:47
118 Tech's Avatar
118 Tech 118 Tech is offline
TECHsan
AKA: Chris David
FRC #1817 (Llano Estacado RoboRaiders)
118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light
Linux Newbie here. Just starting to learn Redhat 9. For my dual boot setup I used this tip from Kevin Rose from TechTV.
Basicly what i have is a switch that changes the master slave configuration on my hardrives. Its really easy to do and you dont have to mess with the Linux bootloader. That is a plus right now becuase i am a newbie.
so far
/me likes linux
Chris David
Software Engineer
SnapStream Media
118 Robonauts
2000-2001
"Once a Robonaut always a Robonaut"
1817 Llano Estacado RoboRaiders
2006-2007
Couchville - Simple TV Listings
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
MS Linux D.J. Fluck Chit-Chat 5 21-05-2002 17:47
