Go to Post And people laugh at me when I suggest 14" wheels. - Munchskull [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 28-04-2003, 09:51
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
TEchnokats...
If you want i would be happy to grab some of my team members...pile into my van and drive over to kokomo and help you debug this problem if you want to take some time and fix it in the offseason. We surely could give you some advice on your pneumatic sitiation.
I'm sure we could get your problems all figured out
PS> I once ate the extra gasket in the festo...doesn't taste good and takes for ever to bite through it.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 28-04-2003, 14:53
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
solution
Taking a page out of our top advisors book, first you need to use a gryo to control your grounding bus, then you need to grease the leadscrew so you will have good connection, finally grind the leadscrew to have a countercolckwise thread!!!!!! The 3 g's of team 222. It always works and don't be too liberal with the grease. If every member on the team doesn't get grease on them at least once from the robot, you need much more!!!
cliff
222 alum
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 28-04-2003, 15:35
Re: solution
Originally posted by camtunkpa
then you need to grease the leadscrew so you will have good connection, ...It always works and don't be too liberal with the grease. If every member on the team doesn't get grease on them at least once from the robot, you need much more!!!
cliff
222 alum
Cliff,
Did you mean "stingy" instead of liberal above? I would also add that it is imperative the the grease be conductive, i.e. containing aluminum or copper compounds and that it conform to the rule book specifications. Use #6 grease on battery primary leadscrews and #10 grease on the other screws, color coded, of course!
Unread 28-04-2003, 21:40
AKA: Cliff Mock
no conductive grease
we don't want the ground to be too good. the only grease we use is lithium!
Unread 29-04-2003, 02:20
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
I spent at least half an hour fiddling with the festo, trying to figure out how it worked to no avail. glad to see you got it!
We were the first seeded first-year team at a first-year FIRST regional.
Q&A Discuss: FESTO Help ASAP!!!! CD47-Bot Extra Discussion 3 16-02-2003 10:55
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
Course Curriculum for A First Class, Please Respond ASAP archiver 2001 0 24-06-2002 01:33
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
What is the wiring for the FESTO valve? Nuts4FIRST Technical Discussion 4 12-02-2002 17:14
