Go to Post I think everyone just needs to chill out and realize what the real goal of FIRST is. - Koko Ed [more]
Unread 29-04-2003, 00:30
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Question About Welding
Question:
I need to know if I can weld decorative cast iron to steel tubing with a mig welder or arc welder.
The weld does not need to be very strong because it won't have to hold any load, but how it looks will matter.
Its decorative wrought iron for a fence.
Unread 29-04-2003, 09:09
T967's Avatar
T967 T967 is offline
5 IA teams, WHOs w/me?
AKA: Seth F.
Team Role: Student
T967 is on a distinguished road
Send a message via AIM to T967
That should work. Both your Items Are basicly the same thing. Just a little more carbon in the steel.
Old dude wondering if he can really get back into this crazy thing called FIRST.
Unread 29-04-2003, 12:48
Welding cast iron is an art and requires some special expertise and special material. Apparently, nickel electrodes for arc welding are available at welding supply houses. See here for an example... http://www.weldmark.com/products/wl-sae72000.pdf
I have always heard that brazing is the way to go where cast iron is concerned and there is a wide variety of products available for that as well.
Unread 29-04-2003, 20:00
It's a Bird
AKA: BoogyShoes
It may not be pretty but, can it be done?
Unread 02-05-2003, 15:55
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
You would get the best appearing weld if you TIG weld the joint. I have welded Axle housings (GM 12 bolt) using Crown's Royal 220Tig welding wire. This is a high Nickel content for welding dissimilar metals. Tensile Strength (as welded) 120,000 psi. Should be strong enough to hold fencing together. If you do not have acces to a TIG welder, Crown also makes Royal-220M for arc welders. You'll want to preheat the pieces if they are large for either welding type. If you cannot find Crown welding wires in your area, I would use a filler that has a high nickel content in a similar brand. Hope this helps.
Racing is an incurable addiction!!
Unread 02-05-2003, 19:07
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Brazing
I also suggest Brazing as the way to go, not only will it look better, but welding cast is tough and expensive.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 03-05-2003, 12:54
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Re: Question About Welding
Originally posted by Eric Bareiss
Question:
TIG all the way!!!!
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
No welding? Katie Reynolds Rules/Strategy 7 20-02-2003 17:33
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
