Go to Post Crushing the box makes it much easier to think outside the box. :D - Matt C [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 01-05-2003, 23:23
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
Originally posted by petek
Have you removed any non-original PCI cards you might have?
Have you tried doing the most basic system install (no drivers, no internet, etc.)? I forget what all the options are, but you want to do a minimum install.
Unless I'm mistaken, if it's crashing while checking packages it is before it actually starts installing files on your disk, though.
It probably isn't your problem but I know OS X is supposed to be very finicky about memory timing. I didn't have any RAM problems with my G3 with a variety of sticks (128 & 2x256 MB, all PC 100 CL2). There used to be some RAM test utilities on the web which came out when OS X first appeared. A lot of people had to get new RAM back then because cheap chips would fail Apple's test. You might check on xlr8yourmac.com and macnn.com forums.
BTW since the install my G3's been rock-solid with no crashes for at least a couple of months.
Hmmm I just installed New RAM today... It worked perfectly with OS9. Although for some reason I think it would tell me... not just hang there.
I have tried installing it with the Min. stuff. Still didnt work
The views expressed in my posts are Mine and mine only.
my myspace!
TEACHERS, Get a free copy of Mac OS 10.2 MattK Chit-Chat 26 07-03-2005 18:01
Anyone interested in a webserver? Leon Machado IV Website Design/Showcase 14 25-08-2003 19:45
