Go to Post But on the plus side, we can drive the robot with a DDR pad, which is crazy-stupid-cool. - Not2B [more]
Unread 06-16-2017, 04:28 PM
Kaorin's Avatar
Kaorin Kaorin is offline
AKA: Steven Kao
FRC #4904 (Bot-Provoking)
Rookie Year: 2017
Kaorin has a spectacular aura aboutKaorin has a spectacular aura about
pic: Mars Game 2018 (looking for feedback!)
Unread 06-16-2017, 04:40 PM
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Because Racecar
AKA: Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is on a distinguished road
Re: pic: Mars Game 2018 (looking for feedback!)
Looks hard to manufacture. I could build you one faster out of box tube that would work just as well.
Why would you use round tubing?
- You're going to rotate things (you're not; in fact, now you have to come up with some locking mechanism)
- You're dealing with a complicated tubeframe that doesn't obey clean planes (a la http://fsae.scripts.mit.edu/motorhea...2011_frame.jpg )
- Analysis becomes easier when dealing with a crossection without a direction (are you doing the analysis? If you are, it's still just as easy to do that with box tube)
Circles that go perpindicular to each other are hard. Box tube would make this thing an ease to manufacture. As would making the bogies flat and maybe adding an offset if needed.
Depending on the game, why is it necessary to steer the wheels? Would be surprised if that's needed. Do some searching into FRC #33's 2010 drivetrain; do something akin to that where they force a drop-center for normal operation and turning. If you drop the steering you can also consolidate your power plants/ gearboxes into one per side.
If you must steer the wheels, do something less silly than running a bevel gearbox that still leaves the motor sticking up and preventing you from doing 360 deg of revolution! Might it also be worth to just slap a COTS swerve module on every end rather than design your own?
The 'averaging' or tying-together mechanism is all-together skimpy. I liked something like the linkages you had a while back on something; I'd trust that load path much more than some miter gears that could skip and then your orientation is all wack.
In all, you're basically downsizing a mars rover- which has certain engineering tradeoffs that don't actually matter for your use. You're not being _inspired_ by it and taking this solution and re-implementing it in a more useful way. Understand why Mars rovers are built the way they are (they don't have predictable terrain, equipment is extremely sensitive, sinking may be a concern, power _efficiency_ is crucial).
Formula SAE is now the thing I do. #becauseRacecar
But I'll still be a mentor for like, forever.
Check out what I'm up to: http://thaddeus-maximus.github.io
"So, wait, what kind of engineer are you? Mechanical? Electrical? Software?"
"Yeah pretty much."
Unread 06-17-2017, 03:36 PM
Kaorin's Avatar
AKA: Steven Kao
Rookie Year: 2017
Thanks for your feedback! I totally agree with you- this drivetrain isn't practical for any kind of game that we've seen before. As I mentioned before, it was mostly a fun project that I didn't really design for any specific reason.
I actually designed a locking mechanism for the tubing. There's just a little hole drilled in the end of each one, and a bolt goes through the joint and the tubing, holding them in the correct orientation. Additionally, (contrary to what you mentioned) the cylinders are not perpendicular to each other. The inside of each joint has a flat edge that the end of the tube rests against nice and flush.
My reasoning for sticking the motors up like that was
A)If they were rotated 90 degrees, the VP's would have to deal with a lot of vertical load that they're not good with,
and,
B)Since the motors are mounted to the pivot module, rotating 360 degrees would just tangle the wires. I decided that if an all terrain game that required this kind of drivetrain were to arise, a true omnidirectional drivetrain wouldn't really be necessary, so the motors wouldn't need to be mounted in a way that let them rotate 360.
I'm honestly not too worried about the miter gears slipping... if it works on mars rovers and car differentials it'll probably work here.
Unread 06-19-2017, 07:29 PM
EthanHunter's Avatar
EthanHunter EthanHunter is offline
FRC #1595 (Dragons)
EthanHunter is an unknown quantity at this point
I think that you could make it a little simpler and more robust, without losing much functionality, if you got rid of the swerve modules and had a single speed gearbox to power each side. The torque would be transmitted through chain between the rotating points.
Unread 06-19-2017, 07:55 PM
FRC #1595 (Dragons)
Also, I agree with the other poster - using square tubing and gussets with bearing holes in them would be simpler to manufacture than the circular tubing you're using now. I think the point of what he was saying was that you should use circular tubing when the axes of the tubing aren't planar, presumably since you couldn't take advantage of the level faces of the square tubing.
I think your point about the wheels not needing to turn a full rotation is also true. And the miter gears are fine as long as you make sure they are rigidly held in place to prevent slipping.
Unread 06-19-2017, 11:16 PM
wajirock's Avatar
wajirock wajirock is offline
Safety General
AKA: Mohammed W.
wajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond reputewajirock has a reputation beyond repute
Is there any chance you'd be willing to put the CAD model on GrabCAD? I'd love to get a more in depth view of the model.
Unread 06-19-2017, 11:35 PM
Kaorin's Avatar
AKA: Steven Kao
Rookie Year: 2017
I'm totally willing to! I've actually wanted to start posting stuff there for a while. The only issue is my team uses a "core components" folder where we source our basic parts (bearings, shaft collars, etc...) so I'd have to either copy to components out or upload the 17gb folder to grabcad. I'd be happy to do it though!
Unread 06-20-2017, 12:27 AM
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #3739 (Oakbotics)
cad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud of
If you're using SolidWorks (looks like it based on some of your prior posts) you can do whats called a pack and go. If you go to the file tab at the top right, about half way down you will see the option for it. This will take all associated files of an assembly (drawings, parts and sub-assemblies) and place them into one folder with all links made. It makes sharing files much easier and is great for scenarios such as this.
Unread 06-20-2017, 01:13 AM
Kaorin's Avatar
AKA: Steven Kao
Rookie Year: 2017
That's awesome, thanks for sharing! I'll go ahead and upload it then.
Unread 06-20-2017, 09:22 PM
Kaorin's Avatar
AKA: Steven Kao
Rookie Year: 2017
For all of you who want to see the CAD files, here they are!
I was kind in a rush while doing this, so I didn't name features/use super great cad practices. It's fine though.
https://grabcad.com/library/rocker-b...c-components-1
Unread 06-22-2017, 05:08 PM
Kevin Ainsworth's Avatar
Kevin Ainsworth Kevin Ainsworth is offline
FRC #2451 (Pwnage)
Kevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond reputeKevin Ainsworth has a reputation beyond repute
Great job CAD'ing this concept.
Keep up the great work and don't get discouraged by all the feedback.
The CD community sometimes gets hung up in the details and forgets that sometimes you just want to create something new and exciting.
I really enjoyed looking through your design and can't wait to see what you do next!!!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
