Go to Post You know how grandmothers get shirts that say "Ask me about my grandchildren"? I want one that says "Ask me about my robotics team." - MissInformation [more]
Unread 28-01-2002, 14:12
DanBlock DanBlock is offline
DanBlock is an unknown quantity at this point
Wire running question
It looks like throughout our robot there will be aluminum tubing.
I was wondering if it was OK to run all of our wires through the tubing, or if we need to have all the wires exposed mounted somewhere else. I also would like to know what the dimensions of the control station table will be.
thanks,
Dan
Unread 28-01-2002, 14:19
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Probably Okay...
Running wires through tubes is fine as far as I know. We have done so on several robots and never had any problems with inspection.
Joe J.
Unread 28-01-2002, 14:29
Re:Probabally Ok....
Thanks a lot for your quick response Joe.
-Dan
Unread 28-01-2002, 16:52
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Question You mean the player station???
We dont usually go any longer than 3 feet and any wider than a foot.
I would recomend going anymore than that because each team only has about 6 feet long in space and you need space for the human player and spotter.
Bad Brad
P.S. I don't know what the acual specs are if they have any???????????????/ which I dont think they do. ANY help here?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 28-01-2002, 17:33
Thanks
Yes this should help a bit, I just wanted to get an idea on how big the OI should be.
Thank you for your response,
Dan
Unread 15-02-2002, 14:18
Running wire through the tubing is great way to protect the wires and manage the neatness of the robot if you remember a few small items.
1. Make sure the mechanical guys know that you have wires running through the tubing so that they DO NOT drill, tap, weld, or crush the tubing.
2. Make sure that sharp edges (i.e. drilled holes, saw edges, joined parts) are filed clean and deburred before you pull the wires through. Once you pull you will never be able to inspect them again.
3. Don't over stuff wires into a tube, their current capacity rating goes way down when you do that.
4. Never pull wires that have a junction, connector, wire splice or soldered joint inside the tube. It is not done in practice and should not be done on the robot. Joints come apart when you least expect and you can't reach into the tube to reconnect.
Good Luck All
Unread 16-02-2002, 20:44
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Don't forget to label it all first too
Unread 17-02-2002, 03:37
Stephanie Stephanie is offline
Stew da Baker
AKA: AKA: Steppie86
Stephanie has a spectacular aura aboutStephanie has a spectacular aura aboutStephanie has a spectacular aura about
Send a message via AIM to Stephanie
Alliance station
1'x12' shelf 3' off the floor. look in the manual under "alliance station" under "field construction" for more info, i think it's 2.3...
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Q&A Discuss: Ramp wire CD47-Bot Extra Discussion 2 06-01-2003 20:57
Ramp wire Stephen Kowski Rules/Strategy 1 05-01-2003 11:02
Motor wire sizes Tim Skloss Motors 5 13-02-2002 07:44
wire question James Crivellone Electrical 1 13-02-2002 07:32
