Go to Post Incidentally, this is a good example of why lawyering the FIRST rules is good practice for the real world. By critically analyzing FIRST's errors, you practice for the day when you need to critically analyze legislators' errors (and deliberate trickery). - Tristan Lall [more]
Unread 28-01-2002, 11:44
bmusser bmusser is offline
Brian Musser
FRC #1504 (Desperate Penguins)
bmusser has a spectacular aura aboutbmusser has a spectacular aura aboutbmusser has a spectacular aura about
Question Last year vs. this year Fisher Price Gear
Will First let us use last year's Fisher Price motor? The pinion gear appears to be smaller and would suit our drive train better. First is slow in responding to this question please help.
Unread 28-01-2002, 13:23
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I would guess not.
The stuff in this year's kit is in this year's kit. Last year's stuff can be used (as spares, for example) if it is the SAME as this year's (and you have not improved it prior to the kickoff).
So...
I suppose that you cannot use the Fisher Price motors from last year.
Joe J.
Unread 28-01-2002, 17:28
Dr.Bot
Posts: n/a
Maybe not the motors - but nothing from taking apart the gearbox from last year - and using those gears in this year's gear box........
Also - not certain if all teams got the exact same
FP motors. i.e. some of this year's may be the same as last year's, and the cases look the same.
This whole FP thing reminds me of a comedy routine.
---- I went home last night only to discover everthing in my apartment had been replaced by an exact duplicate. I went over to my neighbor to tell him. He said: "Do I know you?"
Unread 28-01-2002, 18:13
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
after running both sets against each other
i have foudn the following
1: there seems to be more torque produced in this years set
2: this years set seems to be more sturdy takes more abuse
just my .02
dahl
bleh
Unread 29-01-2002, 13:24
Dr.Bot
Posts: n/a
AARGH!!!
We did some surgery on this years versus last years
FP Motors/gearboxes.
1. Last year's motor is appernetly the same as the
loose 'Johnson' motor included in this years kit.
2. The gear press fit on last years motor is 16 tooth and identical in profile to the small portion of the Chipua cluster gear.
3. If we number the gears from highest to lowest speed
(closest to furthest from motor) gear two is the
same. 1, 3, 4 are different.
4. the palstic housing of the gear boxes is slightly different because the #1 gear /motor is in
a slightly different position.
5. If you use last year's housing and #1 gear it woule be fairly easy to modify the FP Gearbox to accomodate the Chipua cluster gear.
(housing and gear 1 from last year 2,3,4 from this year)
6. By just replacing the #1 gear from last year into this year's gearbox, more extensive modification of the gearbox housing would be needed to adapt.
This is all a theoretical exercise - our drive train team has not recommended we adapt or modify the FP gearboxes to accept the Chipua motors. I suspect they might be able to withstand the tourque
if suitable reinforced, they would be realatively slow. (The FP gearboxes are not very efficient.)
I have no question in my mind that using gears or motors from last year's kit is legal. Using last years housing is probably not. Using a complete
FP unit form last year is almost certainly not.
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
Specs on the gear of the fisher price motor archiver 2000 0 23-06-2002 23:23
FISHER PRICE GEAR BOXES archiver 1999 2 23-06-2002 22:07
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
