Go to Post This is high school robotics for fun and education. Let's try and keep it that way. - Rod [more]
Unread 28-01-2002, 18:13
Ghetto_Child's Avatar
Ghetto_Child Ghetto_Child is offline
#0253 (Mills Robotics Team)
Ghetto_Child is an unknown quantity at this point
Exclamation Mabuchi!!!!
hi does anyone know what type of pinion would go on the mabuchi motor?
Unread 28-01-2002, 20:05
P.J. Baker's Avatar
P.J. Baker P.J. Baker is offline
needs a clever user title
FRC #0177 (Bobcat Robotics)
P.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of light
2002 Mabuchi = 2001 FP?
I'll start off with a warning: Please check me on this. I do not have the motors in front of me, but I'm pretty sure that the following is true:
The Mabuchi motor included in the 2002 kit is the same motor that was supplied with the FP assemblies last year, just without a pinion. If this is true, I would have a hard time finding fault with anyone who used last year's motor and pinion on this year's robot. I will check this out tomorrow and make another post.
Otherwise, you just need to find or make a pinion that can be attached to the Mabuchi output shaft. I think the pinion supplied with the FP motors is a 16Tooth, 32 Diametral Pitch, 20 deg. Pressure angle. Something similar (or identical) to this should work fine.
Good Luck,
P.J.
Mabuchi Motor Specs Joe Johnson Motors 2 08-01-2002 16:55
Mabuchi Motor Paul Copioli Motors 1 08-01-2002 10:26
