Go to Post If this information is not 100% correct, you should follow the default advice I have for when anything goes wrong: Blame the Programmers - IKE [more]
View Poll Results: Change game for the Blitz?
No, keep it the same way 3 6.67%
Only change elims to best 2 out of 3 24 53.33%
Change game drastically, Please! 18 40.00%
Voters: 45. You may not vote on this poll
Unread 13-05-2003, 23:48
Erin Rapacki's Avatar
Erin Rapacki Erin Rapacki is offline
General Manager
Erin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond reputeErin Rapacki has a reputation beyond repute
Send a message via AIM to Erin Rapacki
Yea... with the three colored boxes, this is what the 'wall' would look like;
Name:	stack picture.jpg
Unread 13-05-2003, 23:49
ColleenShaver's Avatar
ColleenShaver ColleenShaver is offline
Asst Dir, WPI Robotics Resource Ctr
FRC #0190 (Gompei and the HERD)
ColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of lightColleenShaver is a glorious beacon of light
Send a message via AIM to ColleenShaver
I think the most important things about 'changing' the game is you don't want to create a change in the game that would render some team's robot or initial strategy useless... team's put in much time and effort into their robots and many may not want to do any changes, especially for one competition.
However- here are some suggestions I made for changes to Battlecry when the staff asked for suggestions from all participating teams. The only change being made so far for BC4 is making the elims best 2 of 3 (the right change I think, worked well at Rally this weekend as well):
- Instead of a reduction of points for KOH: Maybe rather than lessen the points for the top, offer a 'Zone Zeal' twist to the game:
Robot in gray carpet: 5 points
Robot in colored carpet: 10 points
Robot in mesh area: 15 points
Robot in HDPE: 25 points
It encourages teams to always get their robot out to the field (5 pts for not moving), plus it gives incentives to teams to build and guard stacks as opposed to just dominating the hill. It would also create some other interesting scoring scenerios (for instance, trying to move into a colored zone at the end points vs. the amount of points you would negate for any bin you were touching) while offering alternative strategies. Of course, the manner of scoring would have to be kept in line with this year's game (as opposed to Zone Zeal) where if you were touching the gray and colored carpets you would get 5, rather than 10, points [You get 25 for the top and none for touching the mesh at all this year, in 2k2 you got the benefit of higher scoring zone if you were touching both]. It would offer stackers, guarders, and OH's some new opportunities for score increases.
- Switch the robot starting positions such that one red and one blue start on each side of the field (rotate robot start positions 90 degrees basically). Obviously, warning teams ASAP would be appropriate for autonomous mode designs, but it could add some excitement to the game. Teams could choose which robot lines up in which position/side of the field.
- Move the 10 seconds of HP time to the end of the match. Would force a new and interesting on-the-fly strategy capability of the students. Change the penalty for not getting off the field in 10 seconds to HP bins not counting (any stacks or points from those bins placed by alliance HPs would be ignored), and the penalty for not being off in 20 seconds a score of zero (rather than robot being shut off). All other human player rules would stay the same including entering and exiting the field through gate, stepping only in colored areas, placing only in colored areas, no throwing of bins, and no contact with robots.
Just some new ideas to consider. Make sure any thing that may affect rules is clearly thought out before and the rules appropriately cleared up to avoid and issues that wouldn't be covered in the regular FIRST rulebook.
Colleen Shaver (Traitor) - Assistant Director, WPI Robotics Resource Center
FRC190 WPI/Mass Academy (2001-Present) :: FRC246 BU/O'Bryant School (2000) :: FRC126 Nypro/Clinton High (1996-1999)
Unread 14-05-2003, 00:06
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Good concept....here's a little more
While I will not be attending the Blitz (most likely), I think this will definitely add to the game. It certainly can't hurt it. I have a couple more suggestions though.
What if the two outer bins were worth slightly less than the middle bin, say 5 and 10. This would make those robot that do take out the whole wall or the middle have a slight advantage...but that one bin could also be stolen or equaled by the other two bins. Just a thought.
My other, crazier thought, is that these colored bins should count at 10 bins, not just an additional 10 points. Say, if you have a stack of 4 bins with 10 on the floor, you would normally get 40 points. If one of those on the floor is a colored one, you would actually get 76 points (4 x 19). If you had a colored one in the stack, you actually get 130 (13 x 10). This would really ramp up the scores and cause some major defense of the colored bins.
In both cases, its still way too easy to push bins out of the zones...but just think...if in the last second you have no stacks, but can put a colored one on top of something else...and you have a mess of 20 bins...you just got yourself 220 points instead of 30.
Think about it everyone.
Kev
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 14-05-2003, 00:16
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I hope you're going to have many, many extra odd-colored bins
--Madison--
...down at the Ozdust!
Unread 14-05-2003, 01:14
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Throw a "hanging bar" above the ramp!
It would certainly be a new spin on things.
25 points to hang.
15 points for the HDPE
10 points for the mesh
Unread 14-05-2003, 12:17
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
Originally posted by M. Krass
Dave L.'s going to come beat you down if you don't watch yourself ...plenty of thought goes into the game.
Erin;
If you have your heart set on changing the game, there are only two things I'd touch -
1. - Change Elimination Rounds to be a 2 of 3 format. This won't have an adverse effect on robot function.
2. - Reduce the value of the ramp points. Because, through the season, so many robots have been modified to do things other than stack, I would try hard to avoid swinging the pendulum too far to the stacking end of things. You'll notice the two other replies are from stacking teams. I think that, by making the ramp points 15 rather than 25, there's still incentive to battle for the top, but stacking has more potential to play a role.
In the end, though, I think that if you do change that point value, the net result will simply be lower scoring rounds. I don't anticipate that stacking will become any more important that it's been for the past two months.
...and, likewise, if you need any help with things, I'd be more than happy to do what I can.
I agree thaqt a lot of thought goes into the game. No one knew that the game was going to be played in the way it was. Maybe they should change the name from "Stack Attack" to "Battle Bins". LOL. It has a hard game to play, but still a lot of fun.
Good Luck To Everyone at the invitationals.
Unread 18-05-2003, 02:58
The Lucas's Avatar
CaMOElot, it is a silly place
Count The Stack
1. Here is an easy way to make stacking more valuable: Multiply the height of the stack by the number of bins in the stack and the number of bins in the color carpeted area. That way a stack of five would be worth 5*5=25 (same as a robot on the ramp) by itself and the other bins would just be a bonus . Opponents will of often clear the bins out of ur zone while u defend/build a stack. I think it is asking too much of a robot to build/defend a stack and defend all the bins in their zone too. It also would lessen the impact of autonomous on the game since a lower number of bins on ur side could be easily overcome with a higher stack (this should make user mode more exciting).
I always thought it was stupid to exclude the bins in the stack from the multiplier. An example of how ludicrous this scoring policy is: If have a stack of 5 but no other bins in ur area it is worth zero points (5*0=0). I thought this years game was intended to be easy to understand and score on the fly. That is rather hard to explain to a spectator (5=0). The current scoring system seems like something my math prof would give us for HW . Try to think about this problem during the heat of competition:
Maximize the function f(x,h) = h * (x-h) where h is the height of the stack and x is the number of bins in your colored area which varies based on autonomous ability and bin pushing ability.
The new scoring function would be simple (f(x,h)= x * h), and its maximum will always be x = h. So keep stacking, it cant hurt. Go for the ultra high score of 2025 with a stack of 45 (45*45=2025). Achieving this nearly impossible task used to be worth 0 .
2. Also to decrease the effect of "descoring" by pushing bins into the gray area by counting bins and stacks in the gray area by the alliance stations as if they were in the colored area (which is small). Then only neutral area for bins would be the ramp (which is huge) and the robot starting areas (hard to fit bins there). I dont think any team really likes "descoring" even if their bot is really good at it. At PARC, our exciting Qualifying Round against 25 ended up with a whopping 9-9 tie cause both sides just tried to reduce the other's score. Every bot in that match fought hard but only got 18 QPs. Also stack defense would be easier if human players could put their stack in the corner braced by the alliance station. This would make any scoring changes that favor stacking more fair, because bots that cant stack could still easily reap the benefits of stacking thru their HP stacks.
Robot Inspector
Unread 18-05-2003, 10:16
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
The more functions and crazy ideas you throw in, the harder it will be for spectators, including ones who were at previous regionals.
My ideas:
King of the Hill: 20 Points
Stacking, (All Bins in zone * Multiplier)
scoring in example:
15 bins are on the blue side. 12 are scattered in stacks of 1 and 2, there is a stack of 3 standing. 2 Blue robots claim the HDPE
12 bins are on the red side. 6 are scattered in stacks of 1 and 2, there is a stack of 6 standing. 1 Red robot claims the HDPE.
Current game score:
(12 * 3 = 36) + (2 * 25 = 50) = 86
(6 * 6 = 36) + (1 * 25 = 25) = 61
Blue Wins, recieves 208 QP's
Proposed game score:
(15 * 3 = 45) + (2 * 20 = 40) = 85
(12 * 6 = 72) + (1 * 20 = 20) = 92
Red Wins. recieves 262 QP's
This would have higher scoring matches, with emphasis on TALL stacks (which we all know are very hard to keep alive). The closer the SHU : Loose Bin ratio is, the more productive it is. I intentionally had equal score, similar bin amounts because it shows the swaying of king of the hill. Play with other scenarios that real games ended with and you'll see it won't sway every match, but it will sway for some of those last second fall-offs or broken down robots.
Many a match could be swayed by 12 points and many times the above scenario has played out.
Unread 18-05-2003, 12:28
My ideas:
scoring in example:
Current game score:
That seems like a pretty good idea. To bad it wasen't played that way. Good Thinking Gadget.
Unread 18-05-2003, 12:30
25 points to hang.
Although it would be cool, think about how hard the game was to understand already. It was hard to explain already, think about how much harder it would be to play it with a bar over the ramp. I already think that there were to many different ways to alter scores. Add another variable, and I would probably be lost. lol.
Good Luck to everyone at the invitationals.
Unread 18-05-2003, 16:11
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
I think JVNn was just being sarcastic.. I see his point- you don't want to change too much of the game or it won't be fun anymore.. For example, if you added two more baskets to a basketball game and threw in another ball, the game would just be utter chaos.. I agree with those who say that only the KOH score/ stack multiplier should be changed.. Keep the game simple and fun..
Unread 18-05-2003, 17:05
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
It seems like the easiest solution that wouldn't change the game too much is just making stacks also count in the bin total. The KOH doesn't have to be changed when you have the extra points from a stack (5 stack = KOH)
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 15-06-2003, 00:35
Nick Mac's Avatar
Nick Mac Nick Mac is offline
Alumni
FRC #0088 (TJ²)
Nick Mac will become famous soon enough
Send a message via AIM to Nick Mac
As long as you don't make things to complicated, then i think the first annual blitz is golden.
Nick Mac
Unread 15-06-2003, 01:41
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
25 points to hang.
hehe *dusts off 2000 robot*
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 15-06-2003, 19:34
Ryan Foley Ryan Foley is online now
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
chage elimination round format to 2 out of 3
make king of the hill points worth less
include the bins in the highest stack as part of the total # of bins on that side (5 bins on ground with a stack of 3 more would be 8*3 = 24)
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Beantown Blitz CANCELLED! Erin Rapacki Off-Season Events 21 30-06-2003 10:44
REGISTRATION Beantown Blitz Erin Rapacki Off-Season Events 3 20-06-2003 14:16
ATTENTION: Beantown Blitz is in the Works! Erin Rapacki Off-Season Events 13 24-04-2003 19:21
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
