Go to Post Never underestimate the power of curious and impatient FIRSTers ;) - kpugh [more]
Unread 14-05-2003, 18:32
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
nothing like trial and error . . . . . .
for auton mode, we used a lightswitch and a AA battery, and I assume that the disable pin would take the same voltage, so maybe just test ports until you find the disabled one. Power is a bit trickier, because it probably needs a higher voltage and you don't want to be sticking higher than AA voltage wires in those ports at random . .
I'm sure someone more knowledgeable will answer soon.
Looking from a different point at "Fixing" punarhero General Forum 27 18-03-2003 18:41
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
How well did the regional competition help preparing? archiver 2001 3 24-06-2002 02:33
