Go to Post The FIRST family is incredible. - Libby Ritchie [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 14-05-2003, 17:43
Jeff484RULES Jeff484RULES is offline
Jeff484RULES is an unknown quantity at this point
Opti Sensors/Gyro Chips
Is it possible to hook up and test optical sensors and/or gyro chips to an EDU Bot, and if so how?
Unread 14-05-2003, 19:03
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Yes. It's easiest if you can get some small electrical connectors found on the LED and switch connections on most modern computer cases, specifically 3 pin connectors (even better if they have wires already attached). These just slide onto the solid pins on the EduBot's motherboard, and, if you scrounged the connectors with attached wires, you can twist the bare wires together, and bind it with Scotch tape. Well, that's what I did, anyway.
The pinouts for the connections to the EduBot are documented and published in the EduBot documentation.
http://www.innovationfirst.com/FIRST...ence_Guide.pdf
Pages 8 and 9.
For the analog inputs, White is +5VDC, Red is the analog input, and Black is Ground.
For the digital inputs, you just short them together.
One problem I faced when connecting the provided optical sensors to the EduBot was the fact that they require 12VDC to operate. The battery pack on the EduBot only provides 5VDC through each individual analog input port. To circumvent this problem, I connected the Vin pin on the optical sensor to the positive terminal on the EduBot's battery pack. The battery only supplies 7.2VDC (perhaps it was 7.6VDC, I can't really remember), but it seemed to be enough to run the sensor. Perhaps popping a single 9V battery on the chassis of whatever you're doing would be a better idea than what I did, but oh well.
If you have any more questions, or need any clarifications, please feel free to ask.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 14-05-2003, 19:28
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
We just gave them their own battery pack and strapped it on. It worked pretty well.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 15-05-2003, 15:10
EDU opti/gyro
Thanks a lot for the help, but just to clarify, there is a blue, brown, black and white wire on the optical sensor. What gets hooked up to what? And does anyone know how to hook up a gyro chip?
Unread 15-05-2003, 16:37
computhief263's Avatar
computhief263 computhief263 is offline
Battlecry...Here We Come!
AKA: "The Freshman"
#0263 (sachem aftershock)
Team Role: Operator
computhief263 is on a distinguished road
Send a message via ICQ to computhief263 Send a message via AIM to computhief263 Send a message via MSN to computhief263 Send a message via Yahoo to computhief263
the pinout 4 the opto sensors is printed on the of the sensor,
to of the wires are power, one is NC, and the other is NO. depentdant on how/ what u are using them 4, either the NO or the NC goto the digital input on the RC/edubot
as 4 the gyro chip, there was a paper the came w/ it, that told the pinout. ive seen it on delphi a few times so try searching 4 it.
hope i could be of some help
Tom "40Watt" Bigelow
Team Electrical/Court Jester
Proud creator of The dongle that nuked the OI, Dj in a bag, and THPD(strobe lights, a hat, a modified flashlight bulb, and a 12v B&D Firestorm™ flashlight make a good combo!)
Unread 15-05-2003, 17:30
Thanks
Thanks a lot everyone, if anyone else has n e thing to add, please feel free to post a reply!
Unread 15-05-2003, 17:54
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
connectors
You can get the connectors for the EDUBot header pins from www.jameco.com.
The part numbers are:
100811 - 2 pin housings ($0.27 each)
157382 - 3 pin housings ($0.27 each)
100765 - female crimp pins ($0.11 each)
You crimp the pins to the wire then slide them into the housings. They have a little tab that locks them into place. You can get a pair of crimpers at Radio Shack, the kind with the square teeth at the front. These pins are crimped with the notch farthest from the handle. Buy 2x as many pins as you need, they're harder to work with than you think.
When you connect the optical sensor you need two pins: one to either NO (normally open) or NC (normally closed) and one ground.
drills and chips Ben.V.293 Technical Discussion 1 07-11-2003 13:11
2003 Drills and Chips Chris Motors 3 12-10-2003 19:02
Counter chips Ryan Meador Programming 9 15-02-2003 00:07
Voodoo Gyro Chips... Ghetto_Child Technical Discussion 3 01-02-2002 16:39
