Go to Post I would like to meet...Andy Baker: I've never met a pig farmer before... - MissInformation [more]
Unread 17-05-2003, 20:01
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
metric gears
would anyone know where I could order some metric gears to match the pinion on the drill?
Unread 17-05-2003, 20:08
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
The drill motor has a 15 tooth, Metric Module .7 gear.
There is only one distributor of these within the US (that I know of, does anyone know of more?)
http://www.pic-design.com/
Unread 18-05-2003, 09:53
Matt Reiland's Avatar
'The' drive behind the drive
Nope, they are the only source that I have found also.
I would recomend ordering a few in the off season since they take a minimum of two weeks to get and they aren't very expensive.
This year we used a 48 tooth to lower the drill down to the Atwood and it worked very well as far as power goes.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 18-05-2003, 11:51
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
PIC is all I have ever found either. Stock Drive and Boston do supply metric gears, but not in the module used by the drill motor.
We used the first planetary stage from the drillo motor gearbox with our own custom output axle. This let us use "standard" parts from that point on.
Also, the first stage on this gearbox matches the output speed pretty well to the speed of the Chip.
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
gears....? archiver 2000 16 23-06-2002 22:58
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
How do i make gears in inventor? mnkysp6353 Inventor 1 16-01-2002 02:31
