Go to Post Right now, it drives around....hopefully tomorrow it will do a LOT more! - MrForbes [more]
Unread 29-01-2002, 20:57
LittleDave LittleDave is offline
#0293 (Beats me????)
LittleDave is on a distinguished road
Send a message via AIM to LittleDave
Traction
What is everyone planing on using for traction? We have an awsome two speed coustom built motorcycle style tranny for the Chippys but im worried that our two 6inch dia 3 inch wide wheels wont provide enough traction and start to slip
Things to keep in mind: F=uN (formula for force of friction) notice no variable for surface area!
Unread 29-01-2002, 21:53
kacz100 kacz100 is offline
Battle Cattle!
#1466 (Webb Robotics)
kacz100 is on a distinguished road
Send a message via AIM to kacz100 Send a message via Yahoo to kacz100
Sounds odd but we are considering using the old classic wheel chair wheels that have been in the kit forever! Go figure our design?
Kacz
Team #40 Alumni 1999 - 2002
Team #885 College Student/Mentor 2003
Team #1466 College Student/Mentor 2004
Unread 29-01-2002, 22:41
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
F=uN is only an approximation...
More than that, carpet damage may be some team's limiting factor. In this case, surface area is huge.
Just food for thought.
Joe J.
Unread 29-01-2002, 22:50
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
Us? We're using a high surface area mechanism *it's a secret soon to be released* with a coating of Neopreme conveyor belt. Great stuff. We have about 16 sq. inches of surface area for each side of the secret mechanism. This thing is a beast. More to come...
~Adam
Unread 29-01-2002, 23:12
Word
That Neoprene Belt you speak of... i think we are and have been using the same stuff on our wheels for years... its from mcmaster car correct?
Unread 29-01-2002, 23:31
Stacy's Avatar
Stacy Stacy is offline
#0353 (Pobots)
Stacy is an unknown quantity at this point
Send a message via AIM to Stacy
Thumbs up
Thumbs up to Neoprene Timing Belt!! We just ordered it and I can't wait for it to come in. We ordered 1" wide with a 3/8" pitch, throw in a few little nails....oh man...
Does anyone else have any suggestions for wheels with A LOT of traction?? Is anyone making their own wheels, and if so, would you mind telling me out of what? (we're trying to make 2-3 sets of different wheels, and everythings interchangable )
STACY
Unread 30-01-2002, 00:03
AdamT's Avatar
#0401
I'll Private Message you.....
Littledave....yup, the same. Great stuff. 122 I think uses that stuff almost every year. We just decided to order a material for traction instead of making it ourselves...
~Adam
Unread 30-01-2002, 00:26
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Exclamation Better get spare motors ......
Too much traction can be a baaaaaddddd thing too depending on what drive system you've chosen.
Don't forget, stalled motors become high current toasters at full voltage.
-and-
Tank tread designs need some slip in order to turn.
I hate the smell of burning motors on competition morning .......
Better get a line on some spares!
Ed Sparks
MECH TECH FRC-3959
Unread 30-01-2002, 00:44
AdamT's Avatar
#0401
I can attest to that!!! Last year we had really cool and hard to build treads. The only problem, is that we had no slippage. So, we'd try and make a hard turn and the fuse would break and it'd take a second to go again. We even just forgot about getting the goals, we couldn't turn with them. This year's is much better. You'll see....
~Adam
Unread 30-01-2002, 19:45
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
Are you planning on shifting on-the-fly? Would anyone that's trying this be willing to post drawings or explain how you're doing it? I believe team 67 was showing off their pneumatic-powered transmission last year but I can't remember how it worked.
Thanks.
Unread 30-01-2002, 20:56
shift on the fly kinda
In our tranny we can shift while moving we just have to write into the program to stop the chippys while the valve fires. I dont have the drawings for the tranny, one of our mentors designed it from scratch and built it in 2 weeks, under 10 lbs a peice and 2 speeds aprox 3 and 12 fps. It is a continous mesh motorcycle syle transmission. Thats all i can say right now. And to connect to the atwoods a shaft was put over them with the exact cut out of the teeth in it.
Unread 30-01-2002, 22:42
AdamT's Avatar
#0401
We won't really shift "one the fly" because we're changing between going 9 fps to 1 fps. Big change....
~Adam
Unread 31-01-2002, 14:55
Neill Means Neill Means is offline
#0933 (Sallgood)
Neill Means is an unknown quantity at this point
Other usage for "Belt"
Question: If we use regular "belt" (not timing belt) that is cut apart and glued to a flat surfaces (i.e. a flat plate), is this now allowed in the rules?
There has been some considerable talk and rule changes.
I know the "timing belt" restrictions have been changed, but
I was wondering if the initial "belt" usage restrictions of "any length, any type" has been changed since the kickoff.
Neill Means
Team #933
Unread 31-01-2002, 19:57
#0894 (Chargers)
Belt - Any type, any length
This is still in the Additional Hardware List. Timing belts are included.
Unread 31-01-2002, 19:58
honky
Posts: n/a
traction
we are using the neoprene CUSHIONING that comes in the mats...we used it last year..stuff is unstoppable..wait u'll see
traction groves OCCRA 1 29-10-2003 22:24
Materials for traction parteyboy10 Rules/Strategy 1 13-01-2003 21:15
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
Traction Limited, rather than torque Simon G Technical Discussion 6 23-01-2002 07:08
