Go to Post A coin flip is a wonderful thing. Not because it makes the decision for you, but because when the coin is in the air, you realize what you really want. - ATannahill [more]
Unread 27-05-2003, 16:25
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
how do i control a piston with a joystick
hi there.
I'm having trouble figuring this out.
How can i program a joystick to turn a relay on forward when it goes beyond a certain point (say beyond 147) and backwards when in the opposite direction (beyond for example) and then when the joystick is neutral, the relay is off. We are trying to get a joystick (port 4) to control our piston that moves the arm up and down (relay 6)
Thanks
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 27-05-2003, 17:02
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Well, the easiest solution would be:
relay6_fwd=0
relay6_rev=0
if p4_y > 147 then
relay6_fwd=1
else
if p4_y < 107 then relay6_rev=1
endif
Unread 27-05-2003, 17:13
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
try this...
If p4_y > 147 Then
'lift arm up
relay6_fwd = 1
Else
If p4_y < 100 Then
'lower arm
relay6_fwd = 0
Else
'do nothing
Endif
Endif
Note that the above code is from memory and I may have the variable names a bit mixed up.
Also, I don't know how your robot is plumbed. It may be that I don't turn on the relays in the right order or direction or maybe even you use an exotic combination of valves and such that you need to do more that what I suggested to put the arm up or to lower it. But... ... you should be able to figure things out from the code example. Also, you probably need to have something initializing the position when the robot resets or is powered up just to be sure that you are in the state you want to be in when you wake up.
Good luck.
Joe J.
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
speed control punarhero Technical Discussion 11 24-01-2002 18:03
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
