Go to Post Duh! Sometimes the simplest answers are the best ones! - dlavery [more]
Unread 27-05-2003, 09:51
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Why can't you use 255 in PWM?
I've heard that most people don't allow their PWMs to go to 255 and that it has something to do with the serout command. Nowhere in the serout documentation is there a reason given, so I assumed it had something to do with the RC.
Is it because IFI uses 0xff, 0xff as a marker for start of data sequence? If 2 PWMs next to each other in the serial stream were to max out at the same time, it would appear to the master uP as if the data stream had restarted and the remaining variables would be shifted.
If someone knows anything different, I'd appreciate a heads up.
Unread 27-05-2003, 10:54
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Why can't you use 255 in PWM?
That's exactly it.
 Serout USERCPU, OUTBAUD,
[255,255,(PWM1),relayA,(PWM2),relayB,(PWM3),(PWM4), (...)]
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 27-05-2003, 20:21
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
last year our programmer didnt know this...i went full in one direction and the robot stops, jerks, goes, stops jerks...
Unread 28-05-2003, 19:20
And it would have to be in the Serout from the Robot Controller that it went haywire, as the OI is programmed to max out any analog input at 254, unless there is no resistor on the input at all, which goes to 127.
The Serin statement uses the same synchronization method as the Serout, not that a programmer needs that information.
Unread 29-05-2003, 14:50
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
yeah, it sure was fun, making the robot dance, until we realized that...
good rule of thumb, don't let anything get above 254, ever. well, as long as you're the programmer at least .
AIM --> Woloi
Email --> ian@woloschin.com
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pbasic argument question... Ghetto_Child Programming 10 18-02-2002 09:23
