Go to Post OMFG! Sanity prevails! It's unprecedented! - Kevin Sevcik [more]
Unread 01-12-2018, 03:05 PM
zkeen zkeen is offline
Justin N
FRC #0494
zkeen is a jewel in the roughzkeen is a jewel in the roughzkeen is a jewel in the roughzkeen is a jewel in the rough
ADIS16448 Gyro C++ Library
Has the library found at this page not been updated for 2018?
https://github.com/juchong/ADIS16448-RoboRIO-Driver
I put the .cpp and .h in a new cpp program and i get errors dealing with the priority_mutex. Works fine in a java prgram though.
I get ~260 errors like "priority_mutex" was not declared in this scope" and similar issues
Unread 01-12-2018, 06:25 PM
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
Re: ADIS16448 Gyro C++ Library
I just submitted a patch to fix this, which builds in a test project: https://github.com/juchong/ADIS16448...Driver/pull/17. It should probably be tested with the real sensor though, and I don't have one.
Unread 01-12-2018, 06:50 PM
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Updating both C++ and Java are next on the list. Thanks calcmogul! I'll take a look at the updates with a sensor tonight and make any updates if needed.
I'm also going to work on implementing the new "DMA SPI" transfer method instead of the standard WPI Lib method to hopefully increase performance and decrease CPU overhead.
Team 1817 | Llano Estacado RoboRaiders | Mentor | 2007-2011
Team 3730 | NuBots | Mentor | 2012
Team 3005 | RoboChargers| Mentor | 2013-2014
Team 2655 | The Flying Platypi | Mentor | 2014-2018
Analog Devices Inc. | KoP Supplier | FRC Gyro Designer | More Info
Unread 01-14-2018, 11:09 PM
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
That was quick! Take a look at the C++ implementation on GitHub and let me know if you run into any issues! This version should be much more accurate and require less resources than the previous implementation.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
