Go to Post Every game design should be a means to an end. - Mark McLeod [more]
Unread 03-06-2003, 00:54
Breanne M's Avatar
Breanne M Breanne M is offline
Ho Humm... Ho Ho Humm...
AKA: Bree: poor college student
None #0294 (Beach Cities Robotics)
Breanne M is on a distinguished road
Send a message via AIM to Breanne M
Smile almost all true...
Auditory : 52%
Visual : 47%
Left : 50%
Right : 50%
breanne, you are one of those rare individuals who are perfectly "balanced" in both your hemispheric tendencies and your sensory learning preferences. However, there is both good news and bad news.
A problem with hemispheric balance is that you will tend to feel more conflict than someone who has a clearly established dominance. At times the conflict will be between what you feel and what you think but will also involve how you attack problems and how you perceive information. Details which will seem important to the right hemis- phere will be discounted by the left and vice versa, which can present a hindrance to learning efficiently.
In the same vein, you may have a problem with organization. You might organize your time and/or space only to feel the need to reorganize five to ten weeks later.
On the positive side, you bring resources to problem-solving that others may not have. You can perceive the "big picture" and the essential details simultaneously and maintain the cognitive perspective required. You possess sufficient verbal skills to translate your intuition into a form which can be understood by others while still being able to access ideas and concepts which do not lend themselves to language.
Your balanced nature might lead you to second-guess yourself in artistic endeavors, losing some of the fluidity, spontaneity and creativity that otherwise would be yours.
With your balanced sensory styles, you process data alternately, at times visually and other times auditorially. This usage of separate memories may cause you to require more time to integrate information or re-access it. When presented with situations which force purely visual or purely auditory learning, increased anxiety is likely and your learning efficiency will decrease.
Your greatest benefit is that you can succeed in multiple fields due to the great plasticity and flexibility you possess.
Team 294: Beach Cities Robotics
"If I could be the sun, I'd shine in your life. If I could be the rain, I'd rain from your eyes, and I'd wash away the emptiness you feel inside."
~Paul Weller, "As You Lean Into The Light"
"Boys will be boys and so will most middle aged men"
AIM: that13thday
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
Extra ramp and platform outside the field at each event to test and practice? Digo General Forum 4 19-01-2003 21:39
Anyone know how to test motors?? archiver 2000 2 23-06-2002 22:21
NEED A BRAIN? archiver 1999 0 23-06-2002 22:07
Test Track- Ride A Thon!! Joe Matt Championship Event 19 14-04-2002 22:53
