Go to Post The bulk of the hardest fun you'll ever have is opening up that box in early january, and the six week of chaos that that box of parts puts you through. - Joe G. [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 02-06-2003, 22:14
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
Javascript onclick link concatination
hehe, as if the title wan't complicated enought. Ok, i know you can do javascript actions via the onClick command. Is it possible to have the hyperlink (ex http://lightningrobotics.com/?do=news) dynamically change to the same url plus a "&time=(timestamp)" and then transport you to that page. the timestamp would have to be made via php in the javascript at the execution of the javascript. is it possible?
Where has all the fun gone?
Unread 02-06-2003, 22:33
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
If I follow correctly, yes certainly, but I wouldn't know how.
Brrrrrrrrandon!!
Unread 02-06-2003, 22:42
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
yes.. if i get what you're saying correctly...
Here's what you'd need: (be sure the file gets parsed by php )
href="<?php echo "http://lightningrobotics.com/?do=news&".time(); ?>"
that should do it
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 02-06-2003, 23:12
Trashed20's Avatar
that should do it
sorta....
that would create all the links with the timestamp of initial parsing. So you could wait 5 minutes and have the timestamp be 5 minutes old. I need the timestamp right when you click the link. so you click the link (your mouse is still down) the timestamp is thrown in (you let go) and you go to the new url.
Unread 03-06-2003, 00:09
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
here we go:
(note: this is not tested, this is pseudo-code to get you going)
<!--  somewhere up top in 'head' -->
<script language="JavaScript">
   function sendWithTimestamp(url) {
      timestamp = Get.The.Time.Stamp; // <-- said pesudo-code.  :)
      url = url + "&time=" + timestamp;
      window.location(url);  // <-- this may not be right, I forget exactly.
</script>
<!-- then down in the body -->
<a href="javascript:sendWithTimestamp('http://lightningrobotics.com/?do=news');">news</a>
Hope my near-sleep jabber makes any sense & gets you going in the right direction. You may need to make a function to get the timestamp in JavaScript... my book's at work and I'm too lazy to go search for the JS Time functions. I have to leave something for you to do, eh?
Brandon Martus
e-mail
Unread 03-06-2003, 06:08
Trashed20's Avatar
that should work. I actually had a dream about this last night in which i just had the date ammended at the top of the standard page that had something like this:
if (!&GET[time]){
$timestamp=time;
put url thingie here and add time
do a http redirrect thingie to new url with timestamp
i think yours will work better if i can program figure out the rest. more efficient anyway. i'll work on it later tonight but right now i have to ge some skoolin for the last 2 days of my senioryear, yay...
Unread 03-06-2003, 09:08
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
This'll work. You can modify the currentTimestamp() function to fit whatever format you want to use.
script block for the header:
	<SCRIPT LANGUAGE="Javascript">
		// return the current timestamp as a string
		function currentTimestamp()
			var now = new Date();
			var ts = new Array(
				now.getFullYear().toString(),
				now.getMonth().toString(),
				now.getDay().toString(),
				now.getHours().toString(),
				now.getMinutes().toString(),
				now.getSeconds().toString())
			var i;
			var retval = '';
			//pad one-digit values to two and concatenate
			//the order is yyyymmddhhnnss
			for (i=0; i<ts.length; i++)
				if (ts[i].length < 2) ts[i] = '0' + ts[i];
				retval += ts[i];
			return (retval);
		//append the current timestamp to a url and redirect
			// check url for a ?
			if (url.indexOf('?') >= 0) url += '&';
			else url += '?';
			//build the url
			url += 'time=' + escape(currentTimestamp());
			document.location.href = url;
	</SCRIPT>
Usage (the bulletin board software injects a space in "JavaScript", so you'll need to change it in the anchor tag):
<A HREF="javascript:sendWithTimestamp('mypage.php');">MyPage</A>
Unread 03-06-2003, 09:58
Joel J's Avatar
Joel J Joel J is offline
do you..
An observation that may change things: when javascript returns a timestamp, is it not based on the clock of the user's computer, which may or may not be the same as the clock on the server to which the link is directing? It is entirely possible that this is your goal, but I just thought I would point that out.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 03-06-2003, 10:13
busy.
AKA: B. Slash Kamen
True.
You may want to send a flag to the link you are going to, and let the destination page make the timestamp.
<a href="mypage.php?timestamp=1">My Page</a>
<?php
if ($timestamp==1) {
   $time = time();
// continue as planned..
Brandon Martus
e-mail
Unread 03-06-2003, 21:20
HFWang's Avatar
HFWang HFWang is offline
AKA: DarkWulf
#0115
Team Role: Webmaster
HFWang will become famous soon enough
Send a message via ICQ to HFWang Send a message via AIM to HFWang
I'd peresonally do it a different way... the link anyway...
<A
  HREF="mypage.php"
  onClick="
   window.location = this.href + sendWithTimestamp('mypage.php');
   return false;
  ">MyPage</A>
it makes opening in a new window/tab not break...
(spaced to be more readable. remove spaces as needed. :-D)
Unread 04-06-2003, 11:18
None #0116
nice
I didn't even think of that, you're completely right. If you have links targeting a frame or another window you don't want to lose that functionality. You can use a generalized function that sets a querystring value in a URL to do it and use it anywhere. Something like this:
<HTML>
<HEAD>
			var ts = new Array(
			var i;
			var retval = '';
				retval += ts[i];
			return (retval);
		//update a querystring value in a URL or append
		//it to the set if it does not already exist.
		function setQuerystringElement(url, element, value)
			var newUrl = url;
			var params = url.split('?');
			var param;
			var i;
			var found = false;
			//params will have either one or two entries, where
			//entry 0 if the base URL and entry 1 is the querystring
			if (params.length == 1)
				//url has no querystring, so just append element
				return newUrl += '?' + element + '=' + escape(value);
			else
				//save the base url from up above
				newUrl = params[0];
				//divide the querystring into name/value pairs
				params = params[1].split('&');
				for (i=0; i<params.length; i++)
					//divide each pair into a name and value
					param = params[i].split('=');
					if (param[0].toLowerCase() == element.toLowerCase())
						//update the value of the element
						param[1] = value;
						found = true;
					//append the parameter to the URL
					newUrl += (i == 0) ? '?' : '&';
					newUrl += param[0] + '=' + escape(param[1]);
				//if the element was not already in the URL, add it
				if (!found) newUrl += '&' + element + '=' + escape(value);
			return (newUrl);
	</SCRIPT>
</HEAD>
<BODY>
<A HREF="temp.html" target="_blank" onclick="javascript:this.href=setQuerystringElement(this.href, 'time', currentTimestamp()); return true;">Link</A>
</BODY>
</HTML>
