What relay do u hook th pump up to so that it goes on and off buy itself, or does it not matter thanks?
You have to insert code into the program to make the pump turn on and off. Then you hook the pump to whatever relay used in the code. Check the White Papers section, I think the code is there.
Re: Connecting the pump - check out this thread
http://www.chiefdelphi.com/forums/sh...highlight=pump Doug Hogg |
| relay and pwm outputs | nick_champ_2 | Electrical | 1 | 31-01-2003 13:08 |
| Wiring the relay for the pnumatics | Placebo | OCCRA | 3 | 05-11-2002 23:04 |
| Spike Relay Input | nwagers | Electrical | 3 | 16-07-2002 22:23 |
| NEED HELP with Delay loop for compressor relay switch | archiver | 2001 | 10 | 24-06-2002 02:11 |
| Relay Outputs | OddOne | Technical Discussion | 3 | 01-02-2002 19:52 |
