Go to Post We can still do better, even if we've come a long way. - cadandcookies [more]
Unread 08-06-2003, 00:34
Mike Alighieri Mike Alighieri is offline
#0422 (Mech Techs)
Mike Alighieri is an unknown quantity at this point
Exclamation Free Wiring Diagram!
OK, so, we got autonomous this year! Well, if you're like me, it's hard to decide on one autonomous program to run. Especially if you haven't talked with your alliance partner. So, we got this solution... at radioshack, you can buy a little double-pole rotary switch with 6 positions. It took awhile, but I figured out how to wire it together so it only uses 3 inputs. Then just use some code to assign each input to one bit in a variable, and when you turn it it counts from 0 to five in binary. Great for last-minute program selection! Just code it so it branches the program according to the variable. If anyone would like the wiring diagram and/or the code for it, let me know and I'll see what I can do.
Good stuff,
Mike Alighieri
Unread 08-06-2003, 10:26
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
We had many positions on our selector...
High and low speed...
None, one, or both of our wings open...
4 positions on the ramp and 1 not...
We went where you wanted us, how you wanted us, when ever you wanted us...
Thanks to our programmer - Dave...!! W00T!
That rug really tied the room together...
Unread 08-06-2003, 15:58
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Re: Free Wiring Diagram!
Good stuff,
Mike Alighieri
yeah, we used one of those too, but just fpr left, right, normal, and extended autonomous modes
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 08-06-2003, 16:35
D.J. Fluck
Posts: n/a
Ive seen some teams hook that switch up actually physically on their robot and selected it as they set up, other teams (such as us) put the switch on our operator pannel and selected it before we hooked up to the players station
Unread 08-06-2003, 16:41
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Ours was on our control board. We used a 12-position switch from Radio Shack, though we only used 5 of the positions. We also had a left/right switch, giving us a total of 10 programs for both sides.
Jeff Waegelin
Unread 08-06-2003, 17:32
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
we had a 3 postion switch on the robot and a 2 position switch on the OI
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 08-06-2003, 19:38
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
I didnt know the auto mode could be set from the User Interface...we woulda won a lot more matches if we remembered to set it properly.
We had 3 switches on the robot to set auto
Unread 08-06-2003, 19:45
Git 'em!
yeah it basically involves using the competition mode, when the robot is disabled. For a more detailed explination ask in the programming forum.
Robot in 3 Days
Unread 09-06-2003, 12:25
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Team 330, the Beach Bots, had a system where they hit a button on the operator interface and each time they hit it, a counter added 1 and the OI displayed the current setting. They could choose any autonomous mode they wanted with 1 button. I guess they have it set so that when the counter gets to a certain number, it goes back to zero and starts over again.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 09-06-2003, 15:12
O-H
FRC #0048 (Delphi E.L.I.T.E.)
We used a $5 Omron BCD thumbwheel switch from Digikey (SW505-ND, pg. 814, Fig. 3). We wired this to three digital inputs on our OI, giving us 8 programs to choose from (the switch actually has 10 BCD positions 0-9, but we didn't need the extra programs and didn't want to consume an additional OI digital input). The switch had a built-in numeric display to indicate the program number selected, and it was nice have 8 programs at the expense of only 3 digital inputs, but the one button counter increment solution mentioned above is an even better way to conserve I/O.
Unread 09-06-2003, 20:56
...So, we got this solution... at radioshack, you can buy a little double-pole rotary switch with 6 positions.
Good stuff,
Mike Alighieri
Mike,
We used the same switch with a little twist. If you are good at bending metal without breaking it, you can disassemble the switch. Take the contact insulator from the back of the switch. You will notice two, "u" shaped contacts on the rotating insulator inside the body of the switch. Cut the inner contact on just one of the contacts. Then take a look at the metal body of the switch and you will see the metal is dimpled in two places. The dimples are the travel stops for the rotating shaft. Crimp one of the dimples up and out of the way and reassemble the switch. You will now have an eleven position switch. Wire 9k resistors between each of the contacts around the outside of the switch. Add a 10K resistor to the end contact and attach the other end to the 5 volt power supply. Tie the bottom of the resistor string to ground. Add a wire between the two center contacts and take that common point to an analog input. What you will have is a switch that simulates a 100K pot swinging from just under 5 volts to ground with 11 distinct steps. We used this method to select up to 11 different auto modes on the player control box. We were able to then have 11 programs loaded in the robot software (custom circuit board) and ran which ever program seemed appropriate at the time.
BTW this is an old Ham Radio trick. I have a home brew antenna tuner that I use the same switch to select 11 different inductors. I hope Radio Shack doesn't catch on, they'll either jack the price or dump it.
Unread 09-06-2003, 21:53
We bought a similar rotary switch from Glennwood Sales but there was only 1 pin that you had to remove to get a full range of motion, and the technician showed us how to do it.
Note to any Rochester, NY teams: make sure your electrical team knows about Glenwood Sales. It's much better then radio shack (wider selection, better prices).
Unread 20-06-2003, 10:13
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
We had two autonomus modes. But we had one problem with them. To switch between our autonomous modes we had a little box with 3 switches on it. One for disabling the robot, on for switching between autonomous and remote control mode, and one for choosing our autonomous mode. THis box pluged into the competions port of the o/i, well to make a long story short you can only plug one input into the competion port at any given time. We did not think to hard about this and our autonomoous mode wouldn't work because there was no way to choose which one that we wanted. Kinda funny isn't it
"I'm sorry, after all he is just a wookie!"
Unread 20-06-2003, 15:02
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
The competition port doesn't provide any inputs that could be used to select an autonomous program. The only available inputs on the competition port for teams are: Autonomous Enable/Disable, Extra Channel Access Enable/Disable, and Robot Enable/Disable.
Unread 30-06-2003, 11:00
Joe Clohessy's Avatar
Joe Clohessy Joe Clohessy is offline
#0522 (RoboWizards)
Joe Clohessy will become famous soon enough
Send a message via AIM to Joe Clohessy
I would like to know how to change the Auton Mode from either the O/I or the Robot Controler. If anyone has a diagram showing me the wiring schematic that would be great.. You can e-mail it to
WebMaster@RoboWizards.com
--2004 NYC Regional Winners
--2004 NYC DaimlerChrysler Team Spirit Award
--2004 NYC GM Industrial Design Award
--2003 NYC Regional Winners
--2003 NYC Motorola Quality Award Winner
--2003 Philadelphia Eliminations With Team 365 MOE and Team 341 Miss Daisy
--2003 8th seed Championship Curie
--2003 Eliminations With Team Hammond the 2002 Championship Winners and Team 223 Xtreme Heat
Good free 3D CAD software sanddrag Inventor 11 20-10-2003 21:44
Competition port Wiring diagram Joe Clohessy Technical Discussion 14 20-05-2003 12:14
I need free servers compatable with phpBB LBK Rules Website Design/Showcase 19 09-02-2003 20:16
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
