Go to Post I firmly believe that it's within your power to aspire instead of lament. - Alan Anderson [more]
Unread 30-01-2002, 15:07
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Non-variable Victor Control
Simple question for you all:
How can we program the RC to operate the Victor's with a toggle switch?
In other words, we want the speed controller to be on (255) when the switch is on, or off (127) when it's not.
Simple in concept, but our brain trust hasn't been able to make it work in practice.
Your help, as always, is appreciated.
--Madison--
...down at the Ozdust!
Unread 30-01-2002, 15:44
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Assume you're using PWM7.
if button_pressed then toggleOn
PWM7 = 127
goto endToggle
toggleOn:
PWM7 = 254
endToggle
Make sure that you actually pass the PWM value through to the SerOut command (look at the sample for what to send). Also, make sure to limit the value to 254 and not 255. 255 is not a valid output value. The above is mostly in psuedocode but you should be able to figure the rest out.
Matt
Unread 30-01-2002, 16:18
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Try this:
Declare nice_motor as a variable byte
Then state that:
nice_motor = 127 + (127*button1) - (127*button2)
And of course, serout nice_motor to the desired PWM pin
What will happen:
If button 1 is pressed, the motor will go full forward, if button 0 is pressed, it'll go full reverse, and if you press them both (who would do that? ), nothing happens.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 30-01-2002, 16:27
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Yay!
In case you can't tell, I'm on the same team as Micheal. I'm the main programmer, and I have to say, THANK YOU!!!! Now, we can do something that we think is pretty cool, and we can use cool toggle switches too . If you guys are going to the L.I, N.Y.C., or nationals, you'll see why we need the toggle switch controlled pwms. Other than that, if I say anything else, my team members will kill me. So, once again, thanks a whole lot, and good luck to all!
Unread 30-01-2002, 16:29
College? What?
Well, I understood the nice little if statement one (by matt), but the second one makes no sense to me. Sorry if I sound mean, but this is my first year doing PBASIC, and I want to keep it simple. We tried the first solution, and it worked. When we tried to make it work before, we set it to switch the pwm to 255, where as it can only go to 254 (thanks matt). So, end result, problem fixed, controllers of team #810 happy.
Unread 30-01-2002, 17:43
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
would the following make it so you didnt have to edit the serout?
(assume victor is connected to the port for p4_wheel)
if fswitch = 1 goto move
p4_wheel = 127
goto nomove
move:
p4_wheel = 256
nomove:
also would this work better/worse if there was/wasn't a joystick plugged into port 4?
One Team, One Bot, One Fleet of Ambulances!
Unread 30-01-2002, 18:18
College? What?
Well, I made it work using Matt's solution, mostly because that's the simplest (to me at least), because this is the first year I've ever used PBASIC before. I'm surprising myself with how well I already know it (I'm currently the team 810 PBASIC Guru, so t speak), but I still want to keep the program simple.
Another reason why it's easy to keep simple, the motors only have to go foward and off, they don't need to be reversed. This might give a clue to some of you what we're doing, but I'm not telling . If you want to see the secret, you'll have to wait until the L.I. regional. Once again, thanks for all the help. This is one of the best forums I've ever been to, I get a response so fast.
Unread 30-01-2002, 18:57
Re: would the following make it so you didnt have to edit the serout?
p4_wheel = 127
goto nomove
move:
p4_wheel = 256
nomove:
Don't use 256! 256 is equivalent to 0 (the byte will wrap around to zero).
Matt
Unread 30-01-2002, 19:07
College? What?
Don't worry, I'm not using 256. Someone told me it resets the RC, so I've stayed away from it always. 255 I thought was full power, although I guess I'm wrong. Oh well, learn from your mistakes.
Unread 30-01-2002, 20:26
Kai Zhao Kai Zhao is offline
#0686 (Bovine Intervention)
Kai Zhao is on a distinguished road
Send a message via AIM to Kai Zhao
Never use 255. IIRC, two 255's sent in a row is the Main CPU reset signal or something malicious of the kind. Use 254.
Not like it matters anyway. 218 (?) to 254 is all full power, if I remember. And 0 - 36 (?) is all full power. I'm not too sure about the exact values and its something that Dr. Joe would know.
Unread 30-01-2002, 21:05
College? What?
Really? I did not know that. I thought a number of 256 would reset the uP. Hmm, maybe that's why our relays flipped out when we flipped the switch. Oh well, no damage done (I hope). Thanks for all the help, cause now our little sercret works.
Unread 30-01-2002, 22:13
Re: Re: would the following make it so you didnt have to edit the serout?
Matt
I meant to say 254. It's been a long day and I havn't downloaded any sleep lately. With that same code but a 254 instead of a 256 would it work without serout editing? would it work better/worse/not at all if a joystick was/wasn't attached to the port
Unread 30-01-2002, 22:29
Manoel's Avatar
Then simplify the formula to
nice_motor = 127 + (button * 127)
Brazilian Machine
Team # 383
Unread 30-01-2002, 22:57
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
You guys bring tears to my eyes! ;-)
Wow! That was great!
The question was posted at 3:00 and by 11:00 we are all a lot smarter.
This is why I love these forums.
Well done, FIRST online folks.
Keep up the good work.
Joe J.
Unread 31-01-2002, 15:17
College? What?
Yes, I have to agree with Joe. I've pretty much self-taught myself PBASIC over the past two or three weeks. Yeah, it's a bit late to be learning it, but someone else who was supposed to do the programming dropped out. But me and my friend looked through the default code, learned literally every line of that (took about an hour or two), and after that went on to alter the code to our needs. So far, it hasn't been that hard, the math is kind of annoying though. But the coolest thing is that whenever I have a problem, I can just come here and I have an answer right away. Yay for online forums! Now I just wish my team's forums were as active...
variable? manodrum Programming 11 01-04-2003 17:20
Coupling the Chiaphua & a variable Drill output Jeff Sharpe Motors 9 13-01-2003 20:21
Variable Amperage in DC Circuit. How? Jordan A. Electrical 4 01-11-2002 20:26
Dashboard programs and the char variable Ian W. Programming 13 26-06-2002 02:07
what teams have a variable transmissions? Greg Perkins Technical Discussion 4 06-03-2002 06:10
