Go to Post Guys, Can we agree that "we used it in the past" is not a response. Thanks. - Al Skierkiewicz [more]
Unread 31-01-2002, 12:03
junkyarddawg junkyarddawg is offline
junkyarddawg is an unknown quantity at this point
PUlse counting
What is the maximum frequency response of the Robot Controller digital inputs with a medium size program? How can you optimize your code to facilitate counting pulses and determine rate?
Unread 31-01-2002, 15:33
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
40 hz Max, 20 hz or 13 hz more likely
The fastest you can get through the loop is the rate that the radio packets are sent out.
If you do a lot of math, you will be longer than the 25 msec per loop, so you will have to wait for the next data packet.
This means that you will be more likely at a 20hz rate or even 13.3hz.
The best way to keep track of time based stuff this year is to use the custom circuit option that is available this year for the first time.
Joe J.
Counting down to UCF.. Jonathan M. Regional Competitions 14 06-03-2003 19:44
Counting using delta_t and packet_num archiver 2001 2 24-06-2002 00:19
Everyone's counting their chickens... archiver 1999 0 23-06-2002 22:17
1,636 Holes and Counting. Anton Abaya General Forum 13 19-02-2002 11:16
Building a control system Katie Reynolds Technical Discussion 3 16-11-2001 09:34
